Old 02-19-2007, 01:02 PM
Robar Robar is offline
Only struts avail OEM & Koni? Current strut market avail.?
I have been checking, and not having any luck finding any other options. I don't want to go the Koni route.
Gabriel no longer special orders their SVX struts, and has no working inventory.
Carquest states they have KYB special order @ 237 a pop ( nuts!), but KYB has no current part numbers. I have sent them an e-mail for clarification.
Subaruparts has OE for 129 or so. Somebody said 1stSubaruparts sells them for 99, but their web site lists them at 183 ea., with no second option.
Any other products you may know about, please share the info.
Thanks,
Robar
Old 02-19-2007, 02:28 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
other then junk yards and members on the board... you have had alot more luck then most people...
- John
Old 02-21-2007, 08:27 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Try this:
Try abusing (coercing, convicing, etc.) Tokico into producing a run of SVX struts. They have an adjustable series - externally adjustable, that is.
http://www.tokicogasshocks.com/
Old 02-21-2007, 09:29 PM
mbtoloczko's Avatar
sans SVX
For stock struts, try asking Jason at Auburn Subaru. 866 528 5282.
Mychailo
Visit my locker
Old 02-21-2007, 09:31 PM
Suby Fan's Avatar
haha those shocks are staright outta compton!
- John
Old 02-23-2007, 06:07 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Every other subaru site lists the recommended list price on their website aside from subaruparts (which has the customer service of the USSR IMO) but when you call they give you their price. If you do a little grinding work or have a porta power you can use WRX struts as they're nearly identical in size with just the different hub size and some weirdness up top. Problem is you can't buy a set as the rears are way different, you would just need 2 sets of fronts.
Old 03-11-2007, 10:01 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
What kind of weirdness up top? Would the WRX struts work if you used the SVX top mounts? Oh and how much grinding/spreading is needed?
Thanks
'20 Honda Ridgeline
http://www.x35design.com
Old 03-11-2007, 10:52 PM
WRX Struts?
I'm wondering what mod's you are talking about being necessary myself. What the hay would you need a porta power for?
I did talk to Tokico - no way unless there was substantial volume........
It would be nice if something else would fit, but the OE units from Sub parts seems to be the way to go for now.
Old 03-12-2007, 08:35 AM
benebob's Avatar
Thanks
Same difference as an XT6 when doing an Impreza strut swap up front in terms of the hub. Took an hour or so of grinding it down for us. You need to use SVX mounts as the hole pattern isn't the same. The difference is in the threaded nub portion where you attach the top mount. The Imp threads don't go all the way down as the mount is longer so you need a spacer in there to keep the strut tight.
Old 03-12-2007, 10:43 AM
Stevebsy's Avatar
Administrator
Interesting...what year Imp struts did you use?
'20 Honda Ridgeline
Old 03-12-2007, 11:13 AM
But this only works for using Impreza Front struts on the rear of the SVX, as the Impreza struts don't have the sway bar mount on them that you need for the front of the SVX.....
Correct me if I'm wrong Ben....
Old 03-12-2007, 03:21 PM
benebob's Avatar
Yes Huck, I think I said that in one of the early posts. The brackets can easily be fabbed up with a welder I'd suppose if you found the right daring person willing to do it or you could go with an insert and the impreza shell. I'd even suspect you could put an Impreza insert strut into the SVX housing as I think the dimesions are close enough you could make it work. The key is you'd need 2 sets of Impreza fronts (I think they're the fronts but they are the smaller of the two). I used WRX struts from an earlier WRX. Just posted up on NASioc looking for some cheap struts and got 'em delivered for $100. Right now we have the rears on there which on the racer give it the jackrabbit 69 Nova look as we were running the 275s in the rear with a spacer so we needed the clearance around the well. Now with the 22.5 inch tires we'll clear without an issue so it'll be low and lean. Just won't be able to get it on and off the trailer with anything but our 4 (thanks to SVXfiles) doughnuts.
