Old 10-08-2006, 09:31 PM
Archer999's Avatar
Archer999 Archer999 is offline
Arrow power steering leak
Ok, here is the deal. My 92 has a fluid leak. The only fluid that is gets low is the PS fluid. All the other fluids remain at the same level.
The pump that is on the car now is a used pump bought off ebay. I just did a frankenstein install and, let the resevoir burp out all the air. I did not bleed it off from any other point.
Fortunatley, the power steering works at an acceptable level, Although at low speeds it is kinda sluggish. I would like it to feel more powerfull.
The main problem is that this fluid leak is getting onto my exhaust and causes a little smoke at times and an odor.
My question is ...where are the most likely places to look for a power steering leak. The pump and resevior look good, the first hose connecting to the pump looks good.
With the purchase of the pump I also acquired the power steering rack, I guess you would call it. However installation seamed to difficult.
So has anyone else had this kinda problem?????
Old 10-09-2006, 04:48 AM
ItsPeteReally ItsPeteReally is offline
Seeing as I'm never going to patent this, I'll put Pete's leakfinder system into the public domain.
All you need is a roll of white paper toilet tissue, or kleenex tissues, or whatever.
Wrap the tissue around all the joints and components you suspect might be leaking. Use sticky tape, string, or whatever else you have to hand, to keep the tissue in place.
Then just drive the car. If the leak is a bad one it will show up pretty fast, by wetting or discolouring the tissue. If the leak is a slow one, you can keep the tissue in place for a week or so, if necessary.
I wouldn't recommend using this to find a fuel system leak though!!
Oh, and I wouldn't let the paper touch the exhaust system either.
Old 10-09-2006, 11:59 AM
Archer999's Avatar
Chipping away at problems
Well thanks for the advise. I brought it to a shop today to put new tires on it and, they found that one of my CV axles was busted. So, that was spitting grease on my exhaust.
Im going to pick it up in a few hours. Hopefully this will show some improvement.
Old 10-09-2006, 01:31 PM
Fluid will usually leak from the power steering system from the high pressure line or a poorly fitted return hose.
Old 10-09-2006, 04:29 PM
rbalach rbalach is offline
One of the hoses on mine had a pin hole leak on it, I was able to change it out myself. I think it was the high pressure hose, part number 34610C at www.subaruparts.com
Old 10-09-2006, 10:57 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
i will have to try this at work some time
- John
