Old 09-28-2006, 08:28 AM
AJ4U2's Avatar
AJ4U2 AJ4U2 is offline
Help with location and use for
This might sound a little dumb to some but if you don't know you have to ask.
Where are the sensor on these engines
coolant--I know that is water temp.
Speed???
crank????
timing i guess there is one
Are there anymore engine wise to keep it running
Pictures would do i tried to find them in here but no luck
What do they do.
Front engine seals
Cam seals??can you do them with just the removal of th belt and pulley
Crank???Same here.
I got this problem that has been bugging me for months now....When driving interstate doing about 65 and above it like you turn off the switch for a split second and a big jerk go a few miles then agian. I have no codes and below that nothing...all is good or if you just mash the pedal it will just do good until you drive steady above the 55 MPH then it will start again..TPS MAF all been change volts are good to them. Idles perfect fuel miliage around 29.
If you can send me pm or post I need to get this fix soon for a trip is in the making, I have 2 others but i want to take this one and get it fix,
Thanks
Art
Old 09-28-2006, 11:14 AM
Speed???
crank????
What do they do.
Front engine seals
Crank???Same here.
coolant - driver's side top rear of engine (2 wires)
Speed - passenger side top front of tranny
Crank - under alternator
You're correct about the seals...just make sure not to damage the metal around the seals.
Old 09-29-2006, 08:14 AM
AJ4U2's Avatar
Fuel
where is the fuel pump relay on the 92 also the part number for it
Thanks on the other items
Old 09-29-2006, 10:20 AM
Don't know that one...never had a reason to find out
Old 10-01-2006, 04:37 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Before beginning to throw a bunch of parts at it try checking your ignition switch. You wouldn't be the first owner to have a faulty one - in fact, it may just be loose.
Old 10-01-2006, 06:07 PM
AJ4U2's Avatar
Ignition Switch
Done that one still the same. what puzzes me is no codes. In the ecu or trans. It is the most brain strin i have had on a vehicle in a long time. I know it has to be simple because it so diffacult to find. I just don't know where to go from here but the fuel part. Replace fuel filter so far.
Old 10-04-2006, 08:49 AM
AJ4U2's Avatar
Don't trust
Well after weeks of playing around and paying a lot of money out i took it on my own to see if i could find the problem---Well i took all the coils and check them and pull the spark plugs well after a cost of 165.oo for a plug change they forgot to change the last one on the drivers side..I guess it was the hardest one so they left it alone---well i got a set and put all back and it fix the problem no more hiccuping at all, but now i have this gray tail pipes and residue on the rear bumper which looks likes it is running real lean, is this a problem or does these run lean.... I dove it pretty hard after fix to make sure all was ok...It dives like a new one now..
Art
Old 10-04-2006, 11:59 AM
It'll take some miles to re-adjust the ECU's settings....give it a week and go from there.
Glad it's fixed
Old 10-04-2006, 03:32 PM
AJ4U2's Avatar
Thanks
Glad it's fixed
Thanks, I am going to go on a trip with it this weekend about 600 miles we will know how all goes from there. fingers cross
Old 12-17-2006, 12:37 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Im lost, so what fixed the problem ???
new plugs ? or was it new coils ? or ?
did you ever find out the location of the fuel pump relay?
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
