Old 09-27-2006, 10:33 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Blinking CEL... I'm Dumb Founded...
Tonight my friend showed up at the local Euro GTG with her 96 Ebony. Apparently she had a couple seals re-done and vacumm lines replaced. But now shes throwing codes. Apparently the o2 sensors and EGR code. Now, the other issue is, dis-connecting the battery doesn't doesn't clear the codes. So now I'm dumdfounded and don't know. I was going to try putting my stock MAF in and see if that helps the low idle. But as for the O2 sensors and BLINKING CEL I'm lost.
Thanks in advance guys.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 09-27-2006, 10:43 PM
gtdanielgt's Avatar
gtdanielgt gtdanielgt is offline
I miss my VR-4
Send a message via Yahoo to gtdanielgt
go to autozone....they have the OBDII tool and can clear the codes with it if you ask. It's a free service provided by all autozone's...Be courteous though.
Insert Witty Quip Here...
No more subie
Current Cars: 96 Chevy Caprice Impala SS clone
93 Chevy Full-size blazer
Soon: 2002 Honda CBR 954RR
Old 09-27-2006, 10:48 PM
gest24's Avatar
#1 6MT In Cali
She told me they hooked up an OBD2 Tool and it would pull up that there are 2 codes but wouldn't say what they are.
Since its not my car I don't know how much truth is in what she told me or what she was told by the mechanic.
RIP
84 VW Scirocco
02 WRX
Old 09-27-2006, 10:54 PM
gtdanielgt's Avatar
I miss my VR-4
I worked there for 2 1/2 years... It'll pull the codes and say what they are...If for some reason it doesnt say what they are, the autozone employee should have been smart enough to write them down in a slip of paper and cross reference them in the computer thats in the store and it should have said what it is.
Also, there's a n33t little button on the obdII tool that says 'erase' , this will erase any codes stored, but if its a problem that the computer detects immediately, it will come back on after starting the vehicle.
No more subie
Old 09-27-2006, 10:59 PM
gest24's Avatar
#1 6MT In Cali
I'll have to talk to her and work something out. Just frustating I keep telling her to join the network and come to me with any questions or you guys. But she insists on going to a mechanic who never even turned a wrench on this car before he did hers.
RIP
84 VW Scirocco
02 WRX
Old 09-27-2006, 11:59 PM
sounds like a nasty vaccum leak. Maybe they left a line off or cracked off one of the solenoids under the manifold. THe codes may be related to this but not sure. A low jump idle will be an effect of a leak
Old 09-28-2006, 08:59 AM
gest24's Avatar
#1 6MT In Cali
I found a crank case vent hose disconnected. It stableized the idle but was still super low.
RIP
84 VW Scirocco
02 WRX
Old 09-28-2006, 09:42 AM
dwd1985 dwd1985 is offline
I have 2 friends who used to work at Autozone, and htey both say that they can check the codes for you, but cannot clear them because of liability issues. If they chekc the code, and hten clear it, and something happens to your car because of that, then they get in trouble.
