Old 09-25-2006, 04:40 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
No crank problem
Well, I'm getting the bugs out of it slowly but surely, But now it refuses to start. It still thinks it's in first gear, So I disconnected the TCU. I also tested the wires on the starter and the 2 big ones have constant power and the little clip on wire has a constant ground. None of the readings change with the position of the key. What am I missing???
Old 09-25-2006, 04:49 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
a gun, a loaded gun
i dont know
Old 09-25-2006, 04:59 PM
I read your other post about the shift cable.
To make the car think that it isn't in gear. You need to first remove the 17mm nut and the bracket that connects to the shift cable. At that point you can move the indicator manually untill it shows N or P on the dash.
Try to start it, but realise that you may be in gear, so be safe
Old 09-25-2006, 06:09 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Uh... too many threads going. What have you done?
Old 09-25-2006, 08:10 PM
Budfreak's Avatar
Banned
The shift cable was not connected to the tranny when I picked up the car. I manually moved the gear selector on the transmission into neutral after breaking it loose from the first gear position where it was stuck. The shift indicator on the dash indicated 1st gear still though. I completely disconnected the TCU and the plugs from the tranny and that also made no difference.
To sum it all up:
TCU & Tranny connectors unplugged
shift cable disconnected
transmission is in neutral
shifter is in Park
Still no crank!
Old 09-25-2006, 08:32 PM
To sum it all up:
shifter is in Park
Still no crank!
Doesn't matter where the transmission is, if the indicator is showing 1st, it won't start. If that's the case your indicator is bad.
Do you have any bad transmissions sitting around? Pull the indicator off one of them and plug it in.
Old 09-25-2006, 09:15 PM
Budfreak's Avatar
Banned
What if the switch is unplugged though? The indicator doesn't light up now that everything is unplugged. I figured that would allow it to start. I do have a spare switch, but until I can get to it I'm just trying to figure a way to get the thing started.
Old 09-25-2006, 09:23 PM
I had a similar problem with a XT6, unplugging the indicator or TCU wouldn't allow it to start. I had to shift the transmission into R which would show N on the dash and then she would start.
If you have the FSM's you can get the pin-outs and indicator switch diagram to figure a jumper?
Old 09-25-2006, 09:27 PM
Budfreak's Avatar
Banned
How do the manual guys do it?? I think I'll make the trip tomorrow and get the switch, shift cable, and shifter out of my parts car and see what happens.
Old 09-26-2006, 10:21 AM
We use the clutch pedal switch to short 2 wires in the tranny wiring harness.
Old 09-26-2006, 11:04 PM
Budfreak's Avatar
Banned
OK, So the shifter is fixed and so is the gear indicator switch. That got the engine cranking, But now I have the next problem to tackle tomorrow: It won't start due to no fuel flow. I'll run checks on the wiring tomorrow and so on, But just so I know: Where is the fuel pump relay and any fuses related to it?
Old 09-27-2006, 04:08 PM
Budfreak's Avatar
Banned
I checked the fuel pump wiring and voltages and all is good. I remove the top of the tank and I now know the gas gauge isn't working either due to there is probally a half tank of gas and the gauge is all the way on E. Here's my concern: When I reached down into the tank and felt around the bottom, I felt some sort of gooey stuff and when I pulled my hand out I had a black tar substance all over the back of my fingers. I reached under the screen to see if anything was clogging it and it didn't feel gooey under it. The goo was more on the side of the tank right under the pump itself.
Old 09-27-2006, 05:19 PM
Budfreak's Avatar
Banned
OK, so the fuel pump is toast. I got it out and tried it on the battery and it's froze up. The goo turns out to be some sort of rubber disk or something they used under the fuel pump to keep it quiet I'm guessing. But overall, The whole fuel pump assembly was a nasty mess, So I'm gonna get all the guts out of my parts car fuel tank and swap them. It should be running in the next day or 2 with any luck.
Old 09-28-2006, 08:07 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Seems like a lot of us here still have 4 gallons in the tank when the gauge hits empty.
Gene
Gene and Ben
Old 09-28-2006, 09:15 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
If you run a piggie wire from your starter switch to the solinoid (the harness in the back of the ign that sends power to the solinoid via the tcu you can start it in any gear. I did this with my XT to fix the clickiness they all develop and this was a side effect. It should work fine as you'll simply bypass the neutral saftey switch (or whatever its called in an auto).
