Joe,
I doubt the dyno operator would have known the correct drivetrain loss to figure in to determine flywheel hp from wheel measurements. I only know from experience with dynoing svx's. There's really no way to figure what is correct for your friend's car without asking the dyno operator what he did. It's both possible that your friend's transmisison is on the way out and the #'s given by the dyno guy include some % added back to account for drivetrain loss and possible that the #'s are wheel #'s and the dyno just gives optimistic results. On an acurate dyno an svx with a good auto trans measures right around the same as a wrx with a manual trans--just a few hp less than the wrx. |
As you can see from the results that gest24 got when he dyno'ed his car after Young Tom did the 6spd and intake cams, there is variability between dynos (no shock here). What I have done is made sure that each of my dyno runs is on the same dyno to maintain consistency between runs. This will be the 3rd time I've been on Altered Atmosphere's dyno.
-Bill p.s. picked up the car from the shop I did the flexplate replacement at and put the stock rims/tires back on before driving it home...to say there is a visual difference between 55offset/225/50 and 38offset/275/45 is probably an understatement
I have been involved in the development of the electronics for a rolling road dynamometer which was to have been manufactured locally, so am fully aware of how these things work. The are many contingencies which prevents even repeatable accuracy, much less accurate calibration. Furthermore I was at one time sponsored in motor racing, by an organisation specialising in using such a machine, thereby gaining practical experience.
The limitations became patently obvious when differences in figures which caused concern, were not born out in lap times and race results. I therefore only relied on the machine to provide comparative figures during a single test application. Even then there are many factors which may cause errors, varying from one machine to another. Those which incorporate a water brake are most suspect.
Notwithstanding your comment on calibration above, would there be a case for a government institute devising a rig to test each one of these devices once a year say? Here in Ireland we have the NSAI, who check up on everthing that purports to measure or to weigh or whatever. It might just inject a measure [pun intended] of realism to have a comparator that shows what %age the dynos are out, to have them certified and presumably re-adjusted once a year. Would it work? Joe
However this should be applied in respect of wheel alignment machines, which are so often not checked and are faulty. In this case, it is measurement which are being sold.:confused. I have often proven them miles out, using basic fool proof techniques. Cheers for us poor consumers, Trevor
Bill,
Just puttin' on the second coat now!! Quote:
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Bill, best of luck to you. Lets hope for a numer over 180 this time Wanna see close to 100 more? I could come along .........
Then I realize how broke I am and strapped for time and say..."nevermind " Tom |
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty |
Sperry?
What kind of dyno? Where, in Reno?
#28
The SVX was bone stock, right down to the OEM paper air filter element. The RS had a short-ram intake and a header-back exhaust if I remember correctly.
