Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 09-15-2006, 03:18 PM
shotgunslade's Avatar
New Rotors
Out with the old
In with the new
Frozenrotors, slotted only. Yes, Virginia, drilled rotors do crack.
Old 09-15-2006, 07:32 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
I see what looks like 3 other cracks in your picture. That's why solids are the way to go. Glad you found it before the wall found you! Hope the new ones work out a little better.
