Old 09-13-2006, 06:21 PM
crotchrocketony's Avatar
crotchrocketony crotchrocketony is offline
trans binding questions
hey, I just bought a recently rebuilt trans (subaru reman) that has a problem with it binding when turning. stops when you put it in 2wd. this is all info from the guy i got it from that is parting out a few SVXs. story is the awd clutch pack is groved and can be fixed by swaping the tail shaft(with the clutches in it) with my old one (being mine has under 10k on them) other then this the trans works great! any thoughts????
Tony
1992 SVX black/redish 62k awd, rims, brakes..and a few add ons for extra HPs
Old 09-13-2006, 07:03 PM
Tony
Yes Tony you can swap the clutch basket and plates over, from the other box. The only thing is that the two transfer gears are a lapped pair, so to change the clutch basket, that is welded to the top transfer gear, you will have to swap both transfer gears over and match the marks, or risk a gear whine problem.
It seems strange that a Subaru remade box would still have a notched clutch basket in it.
