Old 07-16-2006, 11:45 PM
dynomatt dynomatt is offline
JJ...of course, why didn't I think of you!!! Thanks
Mychailo, thanks to your link it turns out the US only differs in 5th and 6th and a company does the 5th and 6th JDM gears separately. Sooo...what about the US ones? I've widened my search on Nasioc and there's a few come up. Seems around $3k is about the going rate plus or minus?
Anybody got an inside running on the US ones either?
M
Old 07-18-2006, 08:07 AM
mbtoloczko's Avatar
sans SVX
Matt, The US spec 6MTs all have the DCCD center diff. Without the OEM controller electronics and sensors installed, the diff operates as a rear biased open diff, i.e., no limited-slip action at all in the center diff. That's wouldn't be my first choice for an offroad rally car. With that said, there are simple aftermarket electronic controllers that will allow manual control of the center diff LSD action. That's not a great option because it would require constant attention, but it does allow some control. I think the kits sell for around $500-$600 US. Another option would be to rip out the DCCD center diff and put an STi heavy duty viscous center diff. I think that Subaru makes one now for the 6MT. Those are around $800-$1000 US.
Mychailo
Visit my locker
Old 07-18-2006, 06:44 PM
Thanks Mychailo. That's interesting regarding the DCCD controller. My information (possibly incorrect) was that, in the absence of a controller, they defaulted to a viscous centre with a 35:65 split. Not an open centre. I've done one gravel rally stage with an open diff and it was diabolical!!! Never again.
Might need to check that out. I had noticed aftermarket controllers for $149 USD no Ebay. Seemed to just be a knob which changed the lock from not much to a bit. But then it would also be handy to be able to switch it off (ie, go to an open diff when I pull on the handbrake (ebrake to you guys)).
Viscous ones were available from memory. In fact, there's a guy from VA who has a Forester box which is viscous, but has very tall ratios (like top gear and revs for the SVX would put it at over 360km/h!!)
Old 07-18-2006, 08:45 PM
mbtoloczko's Avatar
sans SVX
It definitely does not default to a 35:65 viscous. The DCCD center diff consists of a planetary gear center diff that provides an intrinsic 35f:65r torque split and combines that diff with a magnetically actuated clutch connecting the front and rear drivelines. In absence of a controller, the clutch defaults to completely open.
$149 is definitely a good deal on a controller. Prices have come down signficantly.
Mychailo
Visit my locker
Old 07-18-2006, 09:08 PM
I wonder if it's just a simple case of a circuit with variable resistance applied over the DCCD wires?? Hmmm.
Old 07-19-2006, 05:23 AM
Mychailo,
Further research reveals that with the DCCD disconnected, it defaults to a 34:66 drive ratio. That tells me that the diff isn't open? If it was open, it might be 100:0 or 34:66 or even 50:50 depending on what it felt.
So I think it might not be viscous, but it certainly has the potentially to be able to be run without the DCCD controller
It also seems that this system was designed for rallying. My previous comments about wanting it to disengage when you pull on the handbrake - turns out it does this!!
This link (may require rego) has a scan of the manual relevant:
http://www.clubsub.org.nz/forums/vie...highlight=dccd
Cheers,
MAtt
Old 07-19-2006, 01:18 PM
mbtoloczko's Avatar
sans SVX
Matt,
It can definitely be used for rally, but it works best when it can run in automatic mode rather than manual mode. To get it working in auto mode would require hooking up all the OEM sensors and controller. Not a simple task on a non-STi vehicle.
By "open" diff, I mean that the clutch will be completely disengaged. The plantary gears will still provide an intrinsice 35:65 (or 34:66) front/rear torque split, but with the clutch completely disengaged, if the front wheels or rear wheels loose traction, then all the power will go to the wheels that have lost traction.
With a manual controller, you'll be able to modulate the amount of clutch engagement which will not affect the torque split but will affect what happens when the wheels loose traction. With full engagement, the front and rear drivelines will be forced to rotate at the same speed. When there is partial engagement, there will be some limited amount of coupling between the front and rear drivelines.
This can be compared to an STi viscous center diff. The viscous center diffs all have a 50:50 front/rear torque split provided by a conventional spider gear center diff. The front and rear drivelines are then coupled using a viscous coupling system. With the viscous coupling, as one end of the car looses traction more and more, the viscous coupling provides a greater and greater coupling action between the front and rear drivelines. The coupling action is strong enough with the STi viscous center diffs that if you were, for instance, to break the prop shaft, the viscous coupler would lock up the center diff and you would be able to continue on front wheel drive alone.
Mychailo
Visit my locker
Old 07-19-2006, 03:54 PM
I see. I'm going to have to have a chat to the friend of mine who's running one, without a DCCD controller to understand what they've done.
I'll let you know.
Old 07-19-2006, 06:18 PM
Dccd .
From what I gather, the DCCD uses the same AWD set, that is in the Euro auto. The same compound epicyclic gear set, and clutch. As there is no hydraulics, the clutch must be operated electrically.
Without the clutch operating, it would be like the auto, to have the rear wheels spin. I guess the clutch could be operated, in line with the throttle and rpm. The more throttle, and the lower the rpm, the more clutch is applied. A controller that worked on these lines would be satisfactory.
Old 07-19-2006, 10:11 PM
mbtoloczko's Avatar
sans SVX
Harvey, I don't think its quite the same clutch. The DCCD clutch is magnetically actuated (probably via a large solenoid). Isn't the VTD clutch hydraulically actuated? Anyhow, it should be easy enough to operate the DCCD clutch. The harder part would be building a controller that operates based on sensor inputs.
Mychailo
Visit my locker
Old 07-20-2006, 07:06 PM
Yes I didn't mean the same exactly. I guess it has a magnetic energiser operating the clutch, by a Duty cycle signal like the VTD.
Does the box have two speed sensors fitted? Do you have a link to a cutaway of the box?
Old 07-20-2006, 10:04 PM
As I understand it the best rally drivers use a manual control, usually operated by the navigator on instruction from the driver, who has, or should have, his hands full. This is a real advantage which must be taken up. Anything fixed or automatic is for the slow group.
Old 07-21-2006, 11:22 PM
For a rally car the cheap controllers on Ebay are more than sufficient. They will allow for adjustability of the diff without complete loss of locking. For a street car they are a very different case.
Harvey, there are no more than one speed sensor in the 6mt and it is used for the speedo the auto controller from the factory more or less makes it a limited slip center diff but when it needs to give way for being driven on the street it will allow it without much effort. I am sure the rotational readings from the ABS sensors give the controller a good idea of what it is doing.
Old 07-23-2006, 01:35 AM
Thanks Tom, it looks to me, that the factory controller, operates the Limited Slip clutch, the same as the TCU in my car controls the VTD clutch.
The differences would be that the Controller, either, it can't see wheel spin, or it uses the ABS,as you suggest. Or it just anticipates it, by throttle and speed. The thumb wheel would just raise, or lower the controllers signal.
I reckon that you could trick a SVX TCU into running it in the same mode. Without the two speed sensors, it could not respond to wheel spin. That would be up to the driver.
It would just run, using the throttle, engine rpm and road speed, to do the same auto action. It would just need a thumbwheel to offset the throttle signal, to alter the level of the action. Just depends on that the signal level to the magnetic clutch is.
Maybe Matt could try it.
Old 07-25-2006, 01:08 AM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
Matt... Im still waiting on a reply from japan, sorry for the delay, will post as soon as i hear something
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
