Old 07-11-2006, 07:40 PM
Green1995SVX
Need trouble code chart from 1994 SRS Service Manual
I'm working on a dual airbagged SVX which is giving me airbag trouble code 24. My 92 Service manual doesnt show this code on the chart, and i'm betting it's because of the different dual airbag system. My friend has my select monitor and he's out of town.
Any help would be appreciated!
Mike
Old 07-11-2006, 08:42 PM
From the 1994 FSM Supplement: Code 24 is
Airbag module (Driver) harness is open
Roll Connector circuit is open
Airbag Main Harness circuit is open
Airbag Control Module is faulty
It says inspect the Airbag main harness. If it is OK, replace the Airbag Control Module.
If the Airbag main harness is not OK, replace it.
There is a diagram on the next page showing how to inspect the harness. Unfortunately, I do not have a scanner at this time. It is in the 1994 Supplement, Section 5-5, pg.51. Maybe someone has this supplement AND a scanner.
Old 07-11-2006, 09:21 PM
Green1995SVX
Thanks John! You're the best!
