Old 06-08-2006, 08:56 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
running with compressor off
i had my a/c compressor rebuilt last year (dont ask me why i did) and have a warranty which is still good. however, the mechanic at the shop told me that i wouldn't be able to run the car with the compressor and compressor belt off the car. i dont believe this is true. the pulley has been changed to the one piece/lightened at motorsport. and i'd prefer to still drive the car while the compressor is in...re-rebuild.
would there be any damage/problems with running the car with the compressor and compressor belt off?
Old 06-08-2006, 10:49 AM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
no infact you can get better gas milage doing that
- John
Old 06-08-2006, 11:17 AM
Just make sure the hoses are tied down from flopping around.
Old 06-08-2006, 12:09 PM
Suby Fan's Avatar
oh and there is tape around them to that no dirt gets in the system
- John
Old 06-08-2006, 05:50 PM
Manarius's Avatar
Manarius Manarius is offline
Yeah, you should have no problem running without a compressor. A lot of Legacy guys remove theirs because they don't need them or want them. You can even use the stock crank pulley. In your case, do what was said above;
Remove compressor
Tie down tubes
Cover them so they don't inhale anything
Remove accessory belt
Just be careful that you don't try to turn on the A/C system or bad things could happen (ie. don't use the auto temp system and don't turn on the defrost).
-Jason
-Obi Wan Kenobi
Old 06-08-2006, 06:07 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
What the heck would that hurt?? Just because the compressor field goes bad (hypothetically) the rest of the system should go up in smoke?
Old 06-08-2006, 07:27 PM
nysvx10 nysvx10 is offline
How would turning the A/C on or defrost on with the compressor/belt removed cause harm?
Old 06-08-2006, 10:26 PM
nipper nipper is offline
in my wildest dreams i cant ever imagine it making a difference. Mechanic is full of....biomass.
nipper
Old 06-08-2006, 10:39 PM
it's better than my car rumbling and stalling out. i had to find out the hard way not to use "auto" in the car..even though it's set at 72F (roughly 22C)
thanks for the input guys
Old 06-09-2006, 07:56 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
The compressor is the heart of the system, without it nothing else works (in the A/C system). Nothing should happen if you use the climate controls, mechanically speaking.
Old 06-09-2006, 11:04 AM
Just leave it on ECON and drive to your heart's content.
