Instrument Panel lights problem
when i took back the car from repairing last time, all the rights at Instrument Panel, switches and gear shift are gone. it's unlikely all the bulbs ran out at the same time, so my guess is some cable or switches that provide power to those bulbs are not properly connected. could anyone tell me where these cables is? thanks alot.
Check out the 10 amp fuse in the fuse box under the hood. I do believe its labeled "Lights" or something obvious like that. Its the red one two spots down from the far left.
If your marker lights arent coming on either, this is likely the problem
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
The 10A fuse "Illumination Brightness Control" is the #9 fuse (Middle row, second fuse from the left) in the fuse panel under the dash above the driver's kick panel. NOT in the engine compartment. Check your Owner's manual, Section 10-6 to 10-8.
The only 10A fuse in the fuse box under the hood is for the clock. Here is the diagram of the engine compartment fuse box. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 05-29-2006 at 09:24 PM. |
thank you. will check it out tomorrow.
it is the problem of fuse #9. but when i replaced it, it's blown again immediately.
did a search in the forum for this problem, seems to be a wire problem. and i still remember last time they did a mechanical check and replaced one of the headlight bulbs, and when i got back the car, the clock has been reset. so my guess is they could pull out some wires and install them back improperly.
I have had the exact same problem on my car!! Trust me the wiring is fine and so are your switches, along with the bulbs. I found that certain types of fuses blew and didn't. The type that looks like a "Z" blew in the corners of the bends, making first glance very frustrating. Try going to the fuses that have a "arch" in the middle.
