Old 04-06-2006, 06:35 AM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
JDM STi Gears:
1st: 3.636
2nd: 2.375
3rd: 1.761
4th: 1.346
5th: 1.062
6th: 0.842
Final Drive: 3.90
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 04-06-2006, 06:39 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thanks. Give me a second as I'll need to dig through mikecg's old posts to figure out his current tire size. I know he's rolling on a 17 or 18" wheel.
2006 Steel Gray WRX TR (sold)
Old 04-06-2006, 06:56 AM
Chiketkd's Avatar
Okay...
Looking in Mike's locker, it looks like he has a 17" wheel and he had posted this pic of some new BFGoodrich g-Force T/A KDW's he put on prior to the Stage III install:
I'm going to *assume* that the tire size he's using is 245/40/17 (which keeps it close to the stock rolling diameter with 225/50/16 tires).
Approximate max speed in each gear at a 6,500rpm redline is:
1st 34mph
2nd 52mph
3rd 70mph
4th 91mph
5th 115mph
6th 146mph
However, if mikecg shifts at 6,000rpms, max speed in each gear is now:
1st 31mph
2nd 48mph
3rd 64mph
4th 84mph
5th 107mph
6th 134mph
-Chike
P.S. You shouldn't need to shift into 6th gear Mike. However, you need to practicve shifting like a mofo through the first five!
Old 04-06-2006, 08:44 AM
mikecg's Avatar
mikecg mikecg is offline
Originally Posted by Chiketkd
Following Nik Fu's example, my prediction Sunday is a 13.6 @ 108 for your 1/4 mile as I see you having a lot of 'traction' issues!
Traction as far as wheels will be no problem. They barly chirp with a 3000rpm drop into 1st gear. The clutch however does have traction issues.
Also, the max in 6th will be 138mph. blasted '94 speed limiter.
Old 04-06-2006, 08:46 AM
Chiketkd's Avatar
How large are your tires? Was I close in my guesstimation? I know kdw's are pretty darn sticky!!!
Old 04-06-2006, 08:52 AM
Chiketkd's Avatar
I think all of LAN's chips remove the factory speed limiter - but you can check with him on that (unless you've done field testing! )
Old 04-06-2006, 09:20 AM
mikecg's Avatar
rims are 17's
Old 04-06-2006, 09:25 AM
he is running 225 tires on those wheels
Old 04-06-2006, 10:17 AM
Chiketkd's Avatar
As long as they are 225/45/17 tires my numbers won't be off...
Old 04-06-2006, 10:25 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Can wait to see your times, Ill be praying all day for you!
remember, with the walbro you dont ever want to run down to the gas light. The pump is lubricated by the gas, and even a few seconds of running dry can burn it out.
phil
~Phil
Old 04-06-2006, 10:29 AM
mikecg's Avatar
Mike dropped the fuel pump upgrade from the stage III. The stock put is suffient. He did it to bring the cost down a little.
Old 04-06-2006, 10:49 AM
stallion stallion is offline
Do you refer to yourself in the third person, or am I just confused....
Old 04-06-2006, 11:21 AM
mbtoloczko's Avatar
sans SVX
Originally Posted by Nemesis Destiny
JDM STi Gears:
1st: 3.636
2nd: 2.375
3rd: 1.761
4th: 1.346
5th: 1.062
6th: 0.842
Final Drive: 3.90
I thought that mikecg's 6MT was a USDM version with higher gearing. No?
Mychailo
Visit my locker
Old 04-06-2006, 11:36 AM
Chiketkd's Avatar
He mentioned in a thread over on NASIOC that he had a JDM trans and was looking for a way to swap out 5th and 6th gears for taller gears as his cruising rpms were high on the highway.
Here's the thread which got locked for some reason:
http://forums.nasioc.com/forums/showthread.php?t=972771
Old 04-06-2006, 11:37 AM
Chiketkd's Avatar
Mikecg is referring to LAN (who's name also happens to be Mike) in that post.
