Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 03-24-2006, 08:31 AM
hayasa hayasa is offline
ECUtune effect on tranny?
Just thinking that an ECUtune would have a positive effect on the life-span of the tranny. If the engine has more power low in the RPM band (500), where most of the driving takes place, it should *technically* have to downshift fewer times when hitting the gas for passing or other acceleration. Less shifting = less fricton = less heat = longer lifespan. What do you think?
Old 03-24-2006, 04:24 PM
Manarius's Avatar
Manarius Manarius is offline
Not for SVX trannies. I would think, since the ratio is so high (3.545) that it would be better for the tranny at the higher speeds you go. Remember, it's the speed of the tranny that causes the fluid to move, and at low speeds, SVX trannies don't move a whole lot compared to ones geared lower (ie 4.11 or 4.44).
-Jason
-Obi Wan Kenobi
