Old 03-18-2006, 05:32 PM
demonsvx's Avatar
demonsvx demonsvx is offline
building more AK47's
FWD or AWD which transmission is better?
Ive been seeing more FWD SVXs on Autotrader lately and was wondering if the FWD models had suffered as much problems as the AWD. It also seems there are more 1990-1995 FWD Subarus in junkyards to get transmissions from.
1992 SVX LSL Ex wifey has it now pending self destruction 2001 Legacy mods to come 1992 Subaru Legacy 2.2 214k Boob wheels CANT KILL IT
Old 03-18-2006, 06:16 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
FWDs
FWD cars were only made in 94 and 95.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 03-18-2006, 07:16 PM
It's Just Eric's Avatar
Missing in action
FWD tranbsmissions dont explode as easy as the awd ones do. Theres a woman in my town with a fwd svx that has the original engine and transmission. the car has 320,000 miles and counting. Running and shifting strong
my car has the fwd tranny too. No problems as of yet.
What kills the transmissions is heat. The heat is caused by added driveline friction and the weight of the car as well. Tranny coolers help reduce the problem, as does a lower geared transmission (4.44's cope with the cars weight better) the fwd tranny has alot less driveline stress and friction.
R.I.P Cool Signature.
Old 03-18-2006, 09:44 PM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
Also, AWD doesn't help the life of the SVX tranny either. All the traction and torque at low RPMs causes much more wear and tear and HEAT than a FWD tranny would. This is also a problem with the Mitsu 3000GT VR-4
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
Old 03-18-2006, 10:05 PM
Manarius's Avatar
Manarius Manarius is offline
The crazy 3.545 final drive kills the SVX trannies. Because the insides are spinning so slowly, the fluid doesn't move around so much and then parts heat up and then pop goes the transmission. 4EAT's aren't that bad when they have a proper drive ratio (4.11 proves to be quite nice). AWD/FWD can make a difference, but it's irrelevant if you get a good final drive ratio.
-Jason
-Obi Wan Kenobi
Old 03-19-2006, 08:27 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
For the record, Euro/JDM 3.700 transmissions explode just as readily as the US 3.545 ones.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-19-2006, 09:10 AM
Manarius's Avatar
Once again, high drive ratio kills them. The 3.900 on the 91-94 TLegs seems to be as high as the 4EAT can go before you get into tranny exploding territory. Tranny coolers do help alleviate the problem though.
-Jason
-Obi Wan Kenobi
Old 09-24-2006, 09:19 AM
SomethingElse's Avatar
word words wording
resurerection
Does anyone know if a 94 fwd tranny will swap into an awd slot? Im guessing all I have to do is remove the rear driveshaft and swap the axles but are the modules and connectors the same?
Eric
Old 09-25-2006, 07:31 PM
Missing in action
As far as I know, yes, though youll want the fwd tcu. Someone was running an awd tcu with theur fwd tranny and it worked, but as I recollect it shifted rather roughly
It would be easier to swap in a good 4.44 tranny, and more benificial in obvious ways
Old 09-27-2006, 10:01 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Lee
I'd bet they're referring to the 90-95 Legacies.
