Switch for the 1.4 Chip
Question, do you need to install a switch for the 87 octane chip or can you just install the chip and be done with it?
if you want to use the 87 octane code you need to install a switch.
if you don't want to use teh 87 octane code you can just install the chip and be done with it.
chip swap
has anyone tried to put the swap the two chips? this way you would defualt on 87 and switch for premium?
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
It doesn't work that way. If you want to be on the 87 octane code all the time you need to install the wire. You can leave the switch out and just connect straight to the power source if you don't want to be able to switch back to the premium version. Switches are cheap though. You might as well use one and just tuck it up under the dash so you don't have to worry about mounting it.
One place I've installed a switch is in the coin holder. I got the switch from a dead ATX power supply (the master power switch) and mounted it upside down in the top of the coin holder. Very inconspicuous and you can still put coins in there.
i placed my switch beside the shifter.
since there was a hole there from the previous owner's alarm LED light
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
