Old 03-10-2006, 02:05 PM
Jeff Koren
Steering Pump Reservior Leak on Top - How to fix
For about 5+ years, my power steering reservior leaked from what appeared to be around the cap/dipstick. From looking at photos of other SVXs, this seems to be a problem others have. Here is how I fixed it...
  • Go to Home Depot/Lowes and buy a small sheet of thin rubber. The one I got was red and about 6" square and about 1/8" thick (about $1).
  • take the power steering cap/dipstick off and measure the inside and outside diameter necessary to create a gasket out of the rubber.
  • Cut out the gasket. I used a compass to draw up the gasket on the rubber sheet and sharp scissors to cut it out.
  • Install the gasket onto the cap/dipstick. It should have to stretch a bit to get over the tabs that hold the cap/dipstick to the reservior.
  • Put the cap/dipstick back on the reservior. If you cut the gasket to the right size, you should never have to wipe ATF off of the top of the reservior again.
Old 03-10-2006, 02:42 PM
A very inexpensive fix, especially since the list cost on a new cap/dipstick is over $30.00.
Old 03-11-2006, 09:19 AM
That looks like a good fix. Thanks
Old 03-11-2006, 07:58 PM
spinn360's Avatar
spinn360 spinn360 is offline
I'll have to try that one thanks!
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
