Old 03-09-2006, 11:26 PM
92SVXLS-LDC's Avatar
92SVXLS-LDC 92SVXLS-LDC is offline
power antenna
so i investigated my broken power antenna today.. i wondered why even though i know the mast is broken, i never heard the motor... (previous owner disconnected it in the trunk...) okay... so that explains some... but as soon as i turned on my car with it RE-connected the motor wouldnt stop... is this normal? will it stop once i get a new mast? or should i buy a whole new unit??? any help is greatly appreciated
'96 Saab 900 turbo
'95 Passat (drove the wheels off)
'92 SVX Ls-L (smashed/sold)
'88 Acura Legend (wheel fell off)
'90 Audi 80 quattro (50mph into side of truck)
'95 Saab 9000cse turbo (sold)
Old 03-10-2006, 01:21 AM
dmnknightomega6 dmnknightomega6 is offline
I know power antennas are cable driven with a motor driving it and should stop at the stopper on the cable. If there is no mast there is a chance it would keep going on.
I hope this helps
Old 03-10-2006, 12:53 PM
thanks
hey, thanks... that should help!
-drew
'96 Saab 900 turbo
Old 03-10-2006, 11:05 PM
BTW in othe manufacturers you can get just the mast. However I strongly Advise against it as it will kill the seals and eventually the motor. Buy the wholething. Its not worth the hassle since its a pain to begin with.
Check with the others too. we have a unique dual antenna whatnot.
Old 03-11-2006, 12:03 AM
triumph1902's Avatar
triumph1902 triumph1902 is offline
I tried to fix one of those on my old Acura. The mast has a plastic "cable" which basically resembles a zip tie with teeth on one side. This winds around a gear connected to the electric motor. Even though I managed to get it installed, I never got the antenna to extend and retract correctly. It would always stop short or not go far enough. I eventually gave up and bought the whole unit at WallMart (I believe...long time ago). So like it was suggested already, save yourself the grief and buy the whole thing.
Old 03-13-2006, 05:59 AM
dcarrb dcarrb is offline
A dissenting opinion: I replaced the antenna mast on my SVX over two years ago and it has worked perfectly ever since. And while it was a bit of a hassle because the nylon leader "cable" was broken, necessitating complete disassembly and rewinding... if I can do it, anyone can. There's how-to info here. If the motor works it makes no sense to replace the entire unit.
dcb
