Old 02-24-2006, 10:12 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
The best all-around exhaust configuration that I have used is to leave the front alone and put on a high flow cat. I used a dual 2" in/single 2.5" out and then put a 'Y' pipe bringing it right back to dual 2". Then separate piping to separate mufflers and on out. That gave the best flow and sound with 3.54 and 4.11 with or without a 100hp shot of nitrous. You should be able to just as easily use a dual 2" in/dual 2" out cat and cut out the 'middle man'.
Stephen
Old 02-24-2006, 10:17 AM
Use the 2-into-1 high-flow Magnaflow cat (part # 94037). It is OBDII compliant and comes with the bung for the third O2 sensor if you need it,. Otherwise just plug it up. I purchased from performancepeddler.com for $60.77 shipped to my door! Email them with your best offer.
Here is the link:
http://www.performancepeddler.com/se...btnSearch.y=11
On the SVX original main cat, the third O2 sensor (OBDII) is located at the rear of the converter on the top. On the Magnaflow, it is at the front.
In order to get a cleaner reading, we plugged the O2 bung in the front of the Magnaflow cat and welded a bung for the third sensor into the side of the exhaust pipe directly behind the converter. This way the O2 sensor was in the original position and it makes it so much easier to change if needed. We had to lengthen the three wires in the original harness so that the wires on the sensor would reach the new location.
Old 02-24-2006, 05:32 PM
I don't think that Shabib's SVX has any O2 restriction... he has a Gulfian SVX, kinda like mine ... so no catalysts and no Sensors (the damn thing jsut doesn't feel, it just sucks more and more gas...)
BTW, I was talking the other day with him on msn, he mentioned something verrrrrrrrrry interesting about gas prices there... 20 liters of gas cost $6
I heard that thing from many Lebanese who come from Oman or Dubai... I didn't believe it at first and now Shabib confirmed it. Cool, isn't it?
Old 02-24-2006, 05:40 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Originally Posted by lhopp77
"exsust
Sorry, had to.
________________
Brian"
Very cheap shot and without any consideration for the target. I see Americans on here everyday that spell as bad and use terrible grammar. Like SilverSpear said--how much of ANY other language do you speak--let alone, Arabic?
Lee
This is an English speaking forum, when I join an Arabic one you can take all the shots at me you want..
And it was just a joke, please don't blow up my house
Brian
