View Poll Results: Is there anything you would add to this "Kit"?
Yes, you are missing some important things 4 80.00%
No, Looks good to me! 1 20.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old 02-27-2006, 04:50 PM
Speedklix's Avatar
Locker Link Solution
I'd just get them from Subaruparts.com, they've never messed up an order for me, and their prices are great. I always kick myself when I buy somewhere else and on pick up I get the "well in another week we can have the right part..." and some dealers use matrix pricing... before you order check to see if some of your bolts will losen on the timing belt cover... cause you may have to end up buying new backs if the plastic around the nuts breaks.
I wouldn't buy anything for the engine from the aftermarket guys, stick with genuine subaru. Subaruparts.com is
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 02-27-2006, 05:05 PM
Speedklix's Avatar
Originally Posted by TomsSVX
Valve cover seals adn bolt washers
Oh man, how did I miss that?!?
-Mike
[SIGPIC][/SIGPIC]
Old 02-28-2006, 11:05 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Andrew,
I know you're having trouble locating some of these parts on Subaruparts.com and I'll post links to some of them shortly...
-Chike
2006 Steel Gray WRX TR (sold)
Old 02-28-2006, 11:18 AM
Chiketkd's Avatar
Andrew,
You didn't mention this in your original post, but are you still interested in doing your valve cover seals? You may need to register on subaruparts.com BEFORE you can view the following links:
Spark Plugs (and knock sensors if you decide to replace them):
http://www.subaruparts.com/diag/?mod...category=090-A
Timing Belt:
http://www.subaruparts.com/diag/?mod...ategory=013-A2
Valve Cover Seals (note 3-per-side plus the little ones for each bolt):
http://www.subaruparts.com/diag/?mod...category=020-A
PCV valve (part # 02):
http://www.subaruparts.com/diag/?mod...ategory=050-A2
-Chike
Old 02-28-2006, 02:51 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
ok...heres my shopping cart so far:
[IN STOCK] 22401AA370 Spark Plug Platinum x6 $59.21
[IN STOCK] 11810AA000 Air Control Valve $6.86
[IN STOCK] SOA5165109 Oil Filter $6.06
[IN STOCK] 42072PA010 Pt251892 Fuel Filter $20.26
[IN STOCK] 13028AA120 Timing Belt $76.16
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
