Old 02-16-2006, 04:29 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
Problems!!!
I am having a couple problems with my car, of course.
#1 When I removed my kick panel to start wiring for my remote mount battery, I noticed some connectors (3 or 4) disconnected down there and was wondering why?
#2 I just developed a weird noise. It sounds like a flat tire sound from the rear, and is speed, not RPM dependent. It only happens above 45mph or so, and is causing the rear to vibrate.
Any help would be greatly appreciated. Pictures of problem 1 soon, I'm in class now....
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 02-16-2006, 04:34 PM
AvPPoW AvPPoW is offline
#1 is diagnostic connecters, normal
#2 I recommend checking your tire pressures if you're car is AWD. The wheels have to be very close in diameter and if one is low on air/worn unevenly it can throw the whole system off
Old 02-16-2006, 04:38 PM
dwd1985 dwd1985 is offline
Those arent supposed to be plugged into anything. They are used for the onboard Diagnostics. Those 2 blue wires that you will also find down there are inserted into the different slots on those connectors to read trouble codes. Do not worry about them, they are all supposed to be like that.
In terms of the noise coming from the rear tires, it sounds like the wheel bearings, a very common problem on SVX's. Do a search for rear wheel bearings, and you will find tons of information.
Old 02-16-2006, 04:42 PM
Oh yeah, that too. Didn't really make the conection with the "flat tire noise". I feel stupid tonight
Old 02-16-2006, 05:02 PM
it may be that, but i doubt it, i've been thinking it may just be a lug nut. I took it to Precision Tune (I was bored, and the brake inspection was free) and I think they didn't tighten the lugs correctly. Hell, it took them 20 minutes to get them off...... oh well.
Old 02-16-2006, 09:04 PM
ha!!! you were all wrong. I knew the idiots at Precision Tune didn't tighten the lugs tightly. So, I was in the parking lot trying to find a socket that fit and was getting harassed by campus security, oh well
Old 02-16-2006, 10:31 PM
n00b on demand's Avatar
so did you fix it or what
Old 02-19-2006, 08:06 PM
oh, yeah its all good
