Old 01-29-2006, 10:11 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
swaps
Can someone explain in simple terms the meaning of swaps of trans? I keep reading about the number ratios etc. Is this a swap from an automatic to a manual or does it also refer to other changes? Sorry for being naive.
Old 01-29-2006, 10:18 AM
The stock auot has a ring and pinion ratio is 3.54. The auto swaps you are hearing about are 4.11 and 4.44. They allow for better acceleration
Old 01-29-2006, 11:47 AM
dannmarr's Avatar
I work for my SVX
What does the swaps consist of? Changing the whole trans or just parts? Are these parts taken from other cars? Thanks for your patience.
Old 01-29-2006, 12:26 PM
Swapping the whole transmission and the rear differential
Old 01-29-2006, 09:34 PM
dannmarr's Avatar
I work for my SVX
The previous owner had the trans rebuilt. Is there a way for me to know what type of trans I have?
Old 01-29-2006, 10:12 PM
You could look at the sticker on the back plate of the rear diff that lists the diff ratio, but they could have used the stock SVX diff cover (labeled 3.54) on the diff they modified. However it the cover is labeled as a 4.11 or 4.44 I would assume that it was swapped.
You can also make notes of your vehicle speed and engine speed at the shift point from 1st to 2nd to 3rd to 4th.
Post and compare with other members.
Old 01-29-2006, 10:52 PM
US to CDN SVX's Avatar
US to CDN SVX US to CDN SVX is offline
SVX Voyeur
Do you loose top speed with the 4.44?
1992 SVX LSL Peacock 94,000Miles
1981 VW Westfalia 166,000Miles
1995 Volvo 850 Wagon GLE 174,000Miles
1981 FIAT Spider 120,000Miles
50% Boxer
Old 01-29-2006, 11:53 PM
thundering02's Avatar
Giong back to the beaters...
Yes the stock has a top speed of about 200 the 4.11's can get to 170ish and the 444's go to about 140ish.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 01-30-2006, 12:15 AM
DarknessofDeath's Avatar
Inhabitant of Darkness
then would it be better to just get a 5 speed or 6 speed conversion? (as for top speed)?
Old 01-30-2006, 12:34 AM
WRX 5mt has the best top speed. The 4.11 is close to being equal to the 6mt in terms of revs but the 6mt is a little lower
Old 01-30-2006, 08:41 PM
SVX Voyeur
And here I thought it was just Muscle car or Jeep guys the mess with Ratio's in the tranny and diff.
Too Cool.
50% Boxer
Old 01-31-2006, 07:43 AM
At 6000 rpm on a stock tire equipped SVX with a 4.44 4EAT it runs 145.38792 mph, 6940 rpm gives 168.16512 mph.
More than enough to keep up with traffic.
