Old 12-13-2005, 09:25 AM
NapaBavarian's Avatar
Good morning!
I finally understand Symmetrical AWD!
I thought it was something about how it worked, but it isnt, after looking at the dealers display I realized that it is simply the fact if you looked at the powertrain from the top it is symmetrical from one side to the other as compared to some systems that have an offset front driveshaft to the drivers or passangers side...
.Karl.
Old 12-13-2005, 10:15 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
And I thought it was just a marketing term.
Gene
Gene and Ben
Old 12-13-2005, 12:15 PM
I thought it was because the tires were the same size
Old 12-13-2005, 03:04 PM
Boxer6SVX's Avatar
Boxer6SVX Boxer6SVX is offline
Dont Drink and Drift
Can someone post a diagram? How else would you transfer power from a transmission when the back of the engine is against the firewall...
1995 850Ci
1988 Prelude~ B20 swap
2006 Mustang GT (RIP)
Old 12-13-2005, 03:07 PM
Seriously, thats what is... equal length axles. The only other way to do it would be to use a transfer case but that would lose the symetrical design
Old 12-13-2005, 04:09 PM
Boxer6SVX's Avatar
Transfer case... as in 4wd which is in no way symmetrical... All you have to do is look at a 4wd truck's front differential with its unequal axles and you can see that. all 4 of subaru's axles are equal... which I would think in turn would mean a generally much more balanced car.
1995 850Ci
Old 12-13-2005, 05:08 PM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
Blue = engine
Grey = Gearbox
Red = center diff (or transfer case)
This works in this way
The engine bolts up to the righthand side
The big circle (front diff) is where the front drive shafts connect
The lefthand side shows the transfer between top drive, and bottom drive (center diff).
The rear drive shaft bolts on the back(lefthand side)
(nice and simple, im sure to be corrected in more detail )
AND THIS IS WHY SUBARU IS GREAT
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
