Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 11-04-2005, 10:03 AM
ECUtune Stage II reviews
Well I figured with the limited amount of Stage 2 users out there, we would try and post of what we think
I love it... The car pulls up though the rpms that used to lay flat or buck. It will also allow me to further modify the engine without having to worry about MAF restriction. Once the new software is available...v5 with the new idle configurations I will be more than pleased... Thanks LAN for a great product and strong tech support with it!!
Old 11-04-2005, 10:18 AM
shotgunslade's Avatar
Can't say definitively whether or not it is stronger than the Stage 1v4. The best characteristic for me is the smoothness of the throttle response. Before I was chipped, if I nailed it at low to mid rpm's, there would be a slight hesitation, before I got full response. Not the case now. It's very strong at low to mid rpm's. If I leave the climate control on, I get the strong response from a dead stop. If I don't, the idle problem gives me a slight hesitation. Since I am 4EAT, I shift at 6400-6500 rpm, so I didn't really detect the MAF max-out with the Stage1v4. Looking forward to seeing how it works when I have a few more mods under the hood.
Old 11-04-2005, 10:38 AM
RSVX RSVX is offline
Network Design Administrator
Stage II is with NOS, right?
Life is a game. Play to win.
Old 11-04-2005, 11:15 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
The very first versions that were released were for Nitrous.
The Stage 2v4 and v5 which ECUTune released uses a Z32 MAF and software to allow the car to make much more hp than stock.
Go to www.ecutune.com for more info.
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-04-2005, 11:56 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Well, having just taken the NASA-funded time machine out for another spin, i can say the following:
"The 2v5 chip with the z32 MAF is the best thing since sliced bread! I can't believe how easy it made it to beat ChikeBob by several car lengths at the Drag Strip! Given the power it unleashes, the 2v5 with the z32 MAF should be left in the hands of the SVX OBD-I owners only!"
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-04-2005, 07:43 PM
Bill, just face it... that puney engine you have won't be able to max the MAF anyway
Old 11-04-2005, 08:31 PM
SVXRide's Avatar
..... last time I checked, all EG33s are 3.3L....
(okay, until I find a spare one, that is )
-Bill
p.s. Is Jesse coming down for all the fun this weekend? Guess what just showed up today? z32 MAF all the way from Iowa (with connector!) and a box from this interesting shop out in Washington state...
Old 11-04-2005, 08:44 PM
since u can't use that box anyway u wanna send them my way so I can have them for the Capitol meet...as of right now I don't think I am gonna have them in by then... PM me the specs on what u decided I wanna know if they differ from what I wanna do
Old 11-17-2005, 12:52 PM
longassname's Avatar
Just some dude.
The stage 2v5 update ROMs are shipping out today.
Old 11-17-2005, 12:56 PM
AWSOME!!! Hey mike...do you want us to ship the old ones back??
Old 11-17-2005, 01:00 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
Does the Stage 2v4 raise the RPM limit like the 1v4
[SIGPIC][/SIGPIC]
Old 11-17-2005, 01:01 PM
SVXtasy's Avatar
SVXtasy SVXtasy is offline
Turbo Member
Send a message via AIM to SVXtasy
there is a v5? i have not even put the v4's in yet! what is the difference?
www.svxtasy.com
Old 11-17-2005, 01:05 PM
the v4 was defective because the software was written while Mike had his A/C on along with the headlights so idle was all funky with them off
Old 11-17-2005, 01:10 PM
SVXtasy's Avatar
Turbo Member
interesting, well i guess that i should get the new stuff.
www.svxtasy.com
Old 11-17-2005, 01:25 PM
is there actually more hp created or freed up from the stage 2? Does this increase 1/4 mile times?
