SVX runs BAD when cold - fine when warm
When it's cold and I drive her around it almost feels like I'm on the gas, then off the gas, then on the gas, then off the gas ...feels almost jerky like. Not a lot, but definitely noticeable. When the car has warmed up it is completely gone and drives perfectly fine.
So what gives? Where to start?
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
Did you rewire the torque control on the ECU when you did your 5 speed conversion?
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
mine does that to, it almost seems lioke its cutting fuel or timing is off or something, i'd like to know as well
anyone know this problem?
When my car is stone-cold, there is some slight hesitation during the first or second acceleration from a stop, but otherwise, nothing like what you said.
Did you change the exhaust system? Any chance there is an air leak somewhere in the intake?
I have the exact same problem. But it seems to be getting worse, but its also been getting colder so it may have to do with temps more than anything.
92 Honda CBR 600 95 Miata |
I was thinking maybe it's coming from the exhaust system. My car has some leaks that I just can't afford to fix right now and I think needs cats. There's no rotten egg smell, but I removed all the heat shields and there's still something rattling. So I think the insides of the cats maybe have deterorated.
Like I said - the hesitation is hardly noticable ...but it's definitely there when cold.
it is normal.... you should be allowing the car to warm up anyway
Tom |
