Old 10-17-2005, 01:05 PM
clarkerussell
Need info on front engine seals..
Now that I've replaced the power steering lines on my car, I feel more comfortable in tearing it apart. I REALLY need to replace the timing belt and, according to a Subaru dealer, all the "front engine seals". I know the oil pump seal is included, and cam seals (I'm assuming 4 of them), but what other seals are they talking about?
While I'm in the front of the enigne, is there anything else I should change besides the seals and timing belt? Thanks in advance..
Old 10-17-2005, 02:04 PM
dcarrb dcarrb is offline
Depending upon the miles on your car, consider changing the crank seal, water pump, and idler/tensioner pulleys (or bearings). I had the seals and water pump replaced with the timing belt soon after buying the car and will probably do the pulleys the next time around. If you're over 120,000 miles, you might even want to replace the crankshaft pulley.
dcb
Old 10-17-2005, 02:50 PM
mbtoloczko's Avatar
sans SVX
To add to dcarrb, you'll want to do the lower cam seals too. The upper cam seals will not wear out. They are a plug seal that is not subject to wear. From what I've read on this board, the oil pump is pretty tough, and shouldn't need replacement. Definitely do the water pump while you're there. I just replaced the lower cam seals, crank shaft seal, waterpump, and T-belt. Its a fair bit of work, esp if you don't have all the proper tools on hand and have to figure it out as you go along.
Mychailo
Visit my locker
Old 10-17-2005, 03:22 PM
clarkerussell
I found the rear oil seal that appears to be a rear crank, but not the front one. Do you know what the part number is over at subaruparts.com? Thanks.
Clarke
Old 10-17-2005, 03:26 PM
clarkerussell
It would be really nice if there were a list of parts with part numbers that should be replaced at when the timing belt is replaced. If there isn't one out there today, I'll try to assemble one once I'm done...
Old 10-17-2005, 03:35 PM
Try searching the network...I'm sure someone posted it.
Old 10-18-2005, 04:32 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Hey look at my thread called "more oil" dated on 1/31/2005.
I was given the p/n's of all the gaskets and seals to be replaced.
Don't forget the water pump gasket too.
That thread should help you.
1995 Subaru Svx L / AWD
Old 10-18-2005, 07:24 AM
clarkerussell
Wow... I looked before I posted, but I guess I didn't do a good enough job... Thanks for pointing that out! So, what did you end up doing?
Old 10-18-2005, 09:46 AM
msvx95's Avatar
It's just a phase
Well I gave Subaru one arm and one leg......
I prepared a list of all the part numbers including quantities and descriptions and handed it to them and had the parts dept order all the items I needed before I brought the car in. I scheduled the car to have service one week later giving them plenty of time to get the items.
Besides the seals and gaskets, I had them replace timing belt, water pump, oil pump, timing belt idlers, and thermostadt. They even wanted me to get the power steering pump replaced, but that's an expensive part and I didn't have any probs with it, so I kept my current one.
I really needed to order the rear engine seal which I didn't do....I still have a small leak near the back of the engine and near the oil pan.
Old 10-18-2005, 11:01 AM
SubaruPartsGirl SubaruPartsGirl is offline
Parts Hook-Up
I found this to be very helpful when doing timing belts:
http://endwrench.com/main.php?smPID=HTML::home.html
Take a look in the archives for old issues. They did a whole article on timing belts along with several tips needed to complete the job. This is a publication from Subaru meant to help our techs and wholesale customers better service Subaru customers.
Thanks,
Jackie
Old 10-18-2005, 11:11 AM
kuoh kuoh is offline
The front seals aren't too tough, but I thought the engine had to come out to do the rear crank seal?
KuoH
Old 10-18-2005, 11:14 AM
msvx95's Avatar
It's just a phase
I am guessing that too, that's why I didn't have Subaru replace that.....It would have been a whole lot more than an arm and a leg
I really ought to get an estimate to get that seal replaced and also my oil pan gasket looks suspicious too, but how difficult is that to remove...it looks like the cross-member is in the way.
Old 10-18-2005, 05:24 PM
immortal_suby's Avatar
Thread Killah
KuoH
Either the engine comes out or the tranny to do the rear main seal.
Locker Link
2015 BRZ Limited 6MT
Old 10-18-2005, 05:49 PM
Oil pan is irritating. The gasket isn't really a gasket, it is liquid RTV from the factory. Use a 1/4in drive ratchet with extension and universal joints
Old 10-19-2005, 04:30 AM
msvx95's Avatar
It's just a phase
Hmm I thought something was up with the pan....I couldn't tell on subaruparts.com what the part number was to the gasket that would appear on the oil pan.....so that makes sense that it's liquid RTV.
This type of job sounds messy and knuckle-scrapy
