Old 10-06-2005, 04:38 AM
Originally Posted by budfreak1
ok now heres the next question. why do the marks on my timing belt change there position? i put the belt on and lined up the marks and after i started it and shut it off the marks on the belt were way ahead of the marks on the cam and crank but all the timing marks on crank and cams are still properly lined up. i retimed it today cause it didn't seem right and that's when i discovered this. it just seems weak now for some reason and i'm trying to figure out why before race day. like i said all the marks are lined up on the cams and crank and it sounds like it's right now, but it just feels weak and that belt thing kinda threw me. how bout it beav? got a little explanation? thanks, Jason
The marks on the belt will travel around a few rotations, then line up with the pulley marks again, won't they?
Old 10-06-2005, 09:22 AM
mbtoloczko's Avatar
sans SVX
Correct, but its more than a few rotations. Its something like 50-100 rotations.
Mychailo
Visit my locker
Old 10-06-2005, 01:40 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Wink
cool. that's what i was thinking but i wanted to make sure. thanks guys. Jason
Old 10-06-2005, 04:26 PM
Yes I was guessing,
No of teeth on belt divided by 25 teeth on sproket = X times.?
Old 10-06-2005, 04:45 PM
mbtoloczko's Avatar
sans SVX
I was hoping it would only be a few rotations. :-) I wanted to if my old timing belt was properly aligned before removing it. Worked up a pretty good sweat cranking the engine until all the timing marks were lined up.
Mychailo
Visit my locker
Old 10-06-2005, 05:30 PM
Yes you should try lining up the marks on the bevel gears on a Desmo Ducati, the whole 7 of them.
Old 10-07-2005, 02:40 PM
Budfreak's Avatar
Banned
Talking
Yes I was guessing,
that's 24 teeth i think you mean
Old 10-07-2005, 04:12 PM
Actually it would be # of teeth on sproket multiplied by the # of teeth on the belt divided by the largest common divisor of the 2.
That would be the # of teeth until all the marks lined up again.
As for engine revolutions take the # of teeth on the belt and divide by the largest common divisor between the # of teeth on the belt and sproket.
