Autocross Tire size...
Suddenly the 245/45s I'm running on the Bill-Stock ESP SVX aren't looking all that wide
ESP Camaro @ this year's SCCA Nationals event.... -Bill
Holy bejezus!
You're 245/45/16s still look plenty meaty IMHO... -Chike
Chike,
yeah, it will be interesting to see where the "knee in the curve" is regarding how wide a tire to go with on the SVX. The 245/45s are definitely an improvement over the 225/50s. That Camaro has to be running at least 315/45s! -Bill
Our cars are similar in weight & weight distn to the new V8 Audi S4 which uses a 235 sized tire. The R34 Skyline Z-tune that makes over 500 awhp and weighs in at ~3500lbs, has 265 sized tires. Personally, I feel a tire size around 245-265 would probably be the biggest we'll want to go on our cars. -Chike
I don't 'officially' autocross, but I've been running 245s on the last two sets I've owned. If wider tires were available from a reputable manufacturer, I'd be running 'em. My previous Michelins Sport Cups were really wide. My current Bridgestone Potenzas are noticeably narrower. They're both 245s, but Michelins tend to run wide. ...so, for those of you who want the extra inch, go Michelin.
Hoosiers are wider as well it seems in most cases. Bill Dave is gonna talk $$$ about those 275s. Paul thinks he can mount 'em on the stock rims!!!
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
-Bill p.s. I think Paul might be right....seems to me that I've read that the stock rims are either 7.5 or 7.75 inches wide. I'm really interested in how thick of a spacer you'll have to use to keep the inside "face" of the tires off of the inner wheel well. Talk about a "nasty" looking RACE CAR!!!
-Chike
What inner wheel well . I'm thinking that since a 255 will fit w/o rubbing that we shouldn't need much more than about 3/8, maybe 1/2 inches. Now as for the outer fender. Any ideas on good suppliers for fender flares?
I used them only once on my car, but it caused the outside edge of my tire to hit the wheel well when I took corners. I probably could have made them work with a little more -ve camber... -Chike
Guess I should have said "strut" Plenty of suppliers of flares out there ... try J.C. Whitney -Bill
i work at a tire shop and our stock rims are indeed 7.75.
1992 pearl svx (given away) Custom Cold Air Intake Stage1 Shift Kit Brembo Cross-Drilled/ Slotted Rotors. Front and Rear 4.44 gears now in better hands of svxfiles |
Would 245/40/17's fit on the 17x8" Rota Torques with no rubbing issues on the SVX? I'm not sure of the offset of the Torques, but I really like that wheel design. I may get a set in gun metal grey next year... -Chike
