Old 08-23-2005, 04:50 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Thanks Earthworm!! :D
Mucho Gracias
Domo Arigato
Merci
etc, etc
I shall print these off and get them to my shop quickly. With a little luck, and 2.8 hours labor (according to him) I shall have my AWD back.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 08-25-2005, 11:22 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Originally Posted by dcarrb
Inserting a fuse into the normally-open FWD slot in the underhood fuse box electronically prevents AWD from engaging.
dcb
And, there are a lot of people who, when they first buy an SVX, can't resist filling the empty fuse position -- Lucky for them, the fact that their AWD isn't working, brings them here, to the network, where they receive an education.
Randy Johnson
Mike Davis -- at Reading VI
Old 08-26-2005, 12:34 AM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
You mentioned that replacing the mount fixed the problem the first time. You suggested that perhaps the reason it failed was because of a bad oil leak. It seems reasonable to conclude that the carrier bearing bushing may very well be faulty as a result of the leak. If it really does look suspect, it might be prudent to replace it, as you may need a new one anyway. The carrier bearing bushing failed on one of my friend's cars, and it was certainly very noticeable. It took a few guesses before we figured out what was happening. Carrier bearings just aren't one of those parts you normally expect to go bad.
Still, I think you're probably on the right track regarding solenoid C.
UberLocker
Old 08-26-2005, 06:39 AM
dcarrb dcarrb is offline
When I first saw the protective grease packed into in the FWD fuse slot in my car, my heart sank, because it looked like a melted fuse.
dcb
