Old 08-16-2005, 11:15 PM
pnyklr
Headlights/marker lights can I buy new ones?
Looking at the car today noticed the passenger marker light is clearer/newer than the other ones... can I buy them new anyplace .. my usual parts place lists a part # but then it says not available
Old 08-16-2005, 11:20 PM
My drivers side marker is pretty cloudy as well.
There is also a huge hole on the surface that allows dirt inside.
You sure it doesn't just need a good cleaning?
Last I checked these are available at the dealer for about $85, or you can go with clears from Dayle, however thay are not newy new.
Old 08-17-2005, 12:36 AM
pnyklr
Thanks ... he's only got the clear markers I was looking for headlights too
Old 08-17-2005, 12:40 AM
pnyklr
Subaruparts.com has the headlights for $300 a piece
but the marker lights they have 2 different ones ??
01 $72.35 F.combi lamp assembly right hand
02 $72.35 F.combi lamp assembly left hand
03 $49.49 Lens & body complete right hand
04 $49.49 Lens & body complete left hand
Old 08-17-2005, 12:52 AM
svxwannabee
Doesn't smallcar.com have something of the sort?
Old 08-17-2005, 12:55 AM
pnyklr
Small car has something that you replace the face of the lights ?
I was hoping for the whole assembly
Old 08-17-2005, 05:25 AM
Liquor Assassin
if you all saw how foggy mine were you would laugh, how much would it be to replace the whole light section, including the centerpiece?
Old 08-17-2005, 06:54 AM
About $1061.00 plus shipping from subaruparts.com (retail from your dealer runs about $1272.00 plus tax)
84101PA020 Front combination lamp RH $72.35
84101PA030 Front combination lamp LH $72.35
84001PA020 Headlight assembly RH $325.08
84001PA030 Headlight assembly LH $325.08
91065PA000 Front Grille assembly $266.66
Old 08-17-2005, 09:10 AM
I would suggest looking on ebay. The other way is to post in the Wanted/For Sale forum here and if the parts are available, they will reply to your post. Good luck.
Old 08-17-2005, 09:34 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Brasso
If your lens are yellowed or foggy--get some Brasso and give them a good rub. You will be surprised at the results. Coat them with Rain-X after you do it. There are other methods, but this is about the easiest.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 08-17-2005, 01:00 PM
SVXPlanes
Lee
Blue Magic polish (available at a lot of auto part stores) also works like a charm. Takes some elbow grease, but it will clear them up great. Did this on the wife's MX-3 after we had to replace the passenger side headlight and the headlights didn't match anymore. Now you can barely tell the difference.
If you really want to go new, there's a company on Evil-bay that sells new headlight assemblies for about $270 a piece and corner lights in the $50 range.
Search "SVX" and look under the 'e-bay stores'
Old 08-17-2005, 11:04 PM
o.o
Old 08-19-2005, 05:54 PM
At the Dabob meet I cleaned one headlight on someone else's car with Eagle One fine scratch remover. Can you tell which one?
Old 08-20-2005, 08:33 PM
I'm willing to bet that's the same stuff I used.
If only I could remember.
Old 08-20-2005, 11:07 PM
Parts 1 and 2 are the COMPLETE ASSEMBLY, with the bulbs, sockets, screws, brackets, guide pins, etc. Ready to install out of the box.
Parts 3 and 4 are for the LENS BODY ONLY. You will have to transfer all of the miscellaneous parts from the old unit over to the new one.
See the exploded drawing here: http://www.subaruparts.com/diag/?mod...category=841-A
In the drawing, 1 and 2 encompass the entire unit, while 3 and 4 point only to the lens (without the other parts)
