Old 08-06-2005, 09:36 AM
poweredx2 poweredx2 is offline
Flexplate Issue
Has anyone come upon a company that has a stronger flexplate than the stocker,I just had the tranny replace 6 weeks ago and my flexplate is rattling.I think aamco used the old plate but they are searching also for a better flexplate.
Old 08-06-2005, 11:34 AM
I have an extra stocker if u need one. Other than that, I cannot help u
Old 08-06-2005, 11:37 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Flexplates generally only break from two things - excessive crankshaft end-play and/or distorted/out-of-balance torque convertors. A stronger flexplate will only cause something else (read: something more expensive) to break.
Old 08-06-2005, 12:00 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
The stock flexplate isn't very beefy, but I'm convinced it can handle as much power as your NOS system can dish out. LAN has a 4EAT with a stock flexplate in his test car, and it has withstood the power from his Stage II dyno run and Stage 3 system. Svxfiles also uses a 4EAT in his s/c SVX and he has no issues.
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-11-2005, 11:51 AM
This cracked flexplate is the result of someone not propperly installing the torque converter into the transmission.
