Old 08-03-2005, 04:58 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Thanks, this is some helpful information.
After I order and install the shift kit, I will try to play with the adjustments. Looks like Matt has the ideal setting for his car with one to two turns backed off from tight.
1995 Subaru Svx L / AWD
Old 08-03-2005, 06:21 AM
I would try the preset setting as it comes from smallcar first, to use as a point of reference. Then if you are not happy, make adjustments from there. I believe most of the people here with the kit use the preset.
Old 08-03-2005, 07:39 AM
94svxred 94svxred is offline
Ordered mine and it's on the way!!
Old 08-04-2005, 01:53 AM
Shadabob
I am having the same problem as thundering02 with the power light blinking after start up . Does anyone know what is causing this? I used Chike's write up (which rocked) and installation couldn't have been any easier. One thing I noticed was his connections point down, but mine point up, mounting it exactly as he did (?). I tried switching around the connections but still got the blinking light.
Hmm.....what a pain.
Thanks
PS- this is my first post, so hello everybody!
Shadabob
Old 08-04-2005, 04:28 AM
msvx95's Avatar
It's just a phase
Welcome to the site Shadabob
Old 08-04-2005, 07:05 AM
What's the story? is there a problem or not I have one on the way , but If I keep seeing dash light problems I'm not sure if i should install it !!? ANY HELP PLEASE
Old 08-04-2005, 10:45 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thanks
Shadabob
No clue as to what's causing the blinking light other than double-checking that the connection points between the connectors, wires & prongs are properly touching. If not crimped properly, a connector could easily slide off of a prong on the shift kit, or a wire could slip out of the base of the connector. If this happens, then it'll make the circuit incomplete and the TCU/ECU will think you disconnected the resistor.
-Chike
P.S. If your problem still persists, contact small car. You may haver gotten a shift kit which was damaged in some way????
2006 Steel Gray WRX TR (sold)
Old 08-04-2005, 11:35 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chike,
I don't think Small Car is shipping them with the right resistor. My Power light has blinked since I installed the kit in my car (right before the Mason-Dixon meet). Used Tom's Select Monitor to confirm that nothing is wrong with the trans (after doing the self diagnostic routine).
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-04-2005, 02:21 PM
thundering02's Avatar
Giong back to the beaters...
-Chike
PS I have a multimeter and know how to use it.....
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
