View Poll Results: Have you ever expreianced wiper lift?
Yes I have experianced wiper lift at semi normal speeds 100MPH or less. 10 33.33%
No I have never experianced wiper lift and have travled at around 80MPH+ using them, 20 66.67%
Voters: 30. You may not vote on this poll
Old 07-10-2005, 09:02 AM
A couple friends of mine have had problems with the winter blades lifting on other types of vehicles. That may be one of the problems.
Old 07-10-2005, 10:40 AM
CigarJohnny's Avatar
Mine lift at 75mph and higher. Driver's side stays down on the way verticle but on the way down it lifts off the windshield. Not sure what brand of blades are on it. My previous SVX had the same issue and I was running "Trico" blades I believe. I need a better solution and think "Rain-X" is the way to go.
Johnny
Old 07-11-2005, 08:40 AM
MaxImUmZ MaxImUmZ is offline
On a SVX board with a Z31 name
Send a message via AIM to MaxImUmZ Send a message via Yahoo to MaxImUmZ
i just recently purchased my svx and was wondering about this. Rain just blows off my windshield at high speeds. I wasn't sure if it was rain-x(having never used it before) or some weird quirk of a car design. I take it that its rain x?
1995 Red LSi
Mods: ECUTune Stage One, Smallcar shift kit, removed side SVX badges(weight reduction )
Future plans: Alcyone emblem, black out taillights (Not that I think it looks overly good I just like people having no idea what it is and want to add to the confusion)
Old 07-11-2005, 09:34 AM
red95svx
Maybe the nuts that hold the arm to the car are loose? Might be worth a check.
Old 07-11-2005, 03:58 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
When my wiper bolts stripped on my other cars, I drilled a hole straight through the wiper arm and bolt, then inserted a pin. This kept the wiper arm in place. Make sure you use a new drill bit smaller than the bolt.
Old 07-11-2005, 09:02 PM
Green1995SVX
The Genuine SVX wiper blades from the dealer have a small built in 'spoiler' to keep them firmly planted on the windshield at lofty speeds. They're pricey, but well worth it if you're a lead-foot.
Mike
Old 07-11-2005, 09:39 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Maybe we can conclude a premium pair of windshield wipers work bettar on high speed?
I replaced 3 of them at the same time in summer 2003. They're BOSCH and they're still pretty good. Wiping off smooth and quiet. 3 of them cost me more than 30 bucks. They work as good as OEM. To save some money, I chose the lower-end model for the rear one since I don't drive reverse or use them all the times.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 07-12-2005, 10:43 AM
svxsubaru1's Avatar
So it sounds like i need some oem subaru blades, and some rain X. Thanks
Old 07-12-2005, 11:13 AM
svx_commuter's Avatar
I had that problem awhile ago. Still do but I drive slower now so I don't notice it.
I think this might help, twisting the wipper arm so that the blade is angled slightly to the air flow. That may plaster it to the windshield.
I do not like rain-X on the windshield.
This is the previous thread.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 07-12-2005, 11:40 AM
Manarius's Avatar
Manarius Manarius is offline
My windshield wipers work well at about 70 on my Legacy, and there's definitely more air force on them then on an SVX (It's like driving a truck). Generally though, there isn't any times where I need to go 80+ in the rain.
-Jason
-Obi Wan Kenobi
Old 07-12-2005, 01:22 PM
dcarrb dcarrb is offline
Drove through a couple of squall lines yesterday evening on I-575 north of Atlanta and the wipers worked fine. What my car needed was ballast tanks and a periscope. It's amazing that a tropical depression can dump so much water, so far inland.
dcb
Old 07-14-2005, 08:05 PM
mbtoloczko's Avatar
sans SVX
The factory wipers are the way to go. They cost a bit more, but they last forever (mine are 2 years old and still work perfectly), and they have the little bumper that is used park the wipers in summer mode.
Mychailo
Visit my locker
