Old 06-15-2005, 08:48 AM
tracedog67
dealer lost, code 32 and 37
Fellers,
I posted earlier about our '92 SVX (166k). They are getting a 32 and 37 code, which if i look on www.svx-iw.com says is the left hand and right hand O2 sensors, but the dealer says a code 32 is a rear sensor (which the car does not have). Should i just go get the car and do both 02 sensors myself? please help i am getting suspicious of this dealer after they charged me 14.50 for shop supplies to change the transmission mount and 1 hour of diagnostic time. What shop supplies are used to change a tranny mount?
thanks
Tdog
Old 06-15-2005, 09:56 AM
SubaSteevo's Avatar
No longer blue member
I would tell them to go ahead and change the rear sensor, then threaten to sue them for false charges, settle out of court for a new STi
-Steve
01' MSM Lexus IS300
Old 06-15-2005, 09:58 AM
Clydesvx Clydesvx is offline
Way over-the-hill Member
Maybe the dealer keyed in WRX instead of SVX. Rear O2 sensors are a recent addition to the plethera of electronic gizmos. My '03 Forester has one. I would suggest he look under the car and try again!!
'92 LSL TEAL 277,000 miles
Trans (on # 3) Engine (on # 2)
"NEW" VISORS
'03 Forester XS 214,000 miles
'05 Outback 3.0R
Old 06-15-2005, 10:24 AM
red95svx
Subaru has been using rear O2 sensors since at least 1995. The problem is that he's reading the info wrong. In a "normal" Subaru you would have a front and rear sensor. On an OBDII SVX you'd have two fronts and one rear. On your SVX (pre-OBDII) you have two fronts and no rear. At any rate, your car needs both O2 sensors replaced. This is probably causing the rough idle that you mentioned in another post.
Old 06-15-2005, 10:31 AM
red95svx
You mentioned in another post that the rough idle occured after the tranny replacement. Is it possible that one of the O2 sensors was not reconnected after the surgery?
Old 06-16-2005, 10:43 AM
I bet they're both unplugged.
Old 06-16-2005, 02:54 PM
freak customs freak customs is offline
Send a message via ICQ to freak customs Send a message via AIM to freak customs
i vote change the sensors yourself (unless they're just unplugged). the dealer is obviously "confused" about what he's doing on the car.take a good look at the wires and connectors for both o2 sensors... if they're plugged in, they could be damaged and touching something, plugged in incorrectly, etc..
