Old 06-01-2005, 11:23 AM
angrydan angrydan is offline
Driver's Side Window Stuck Down
Hello all,
Coming back from lunch today, I had my window down. When I got back to my office, I was surprised to see that the window would not go back up. When I move the window switch in either direction, i hear a click coming from the switch, but no movement. Does that sound like the window motor?
Dan Taney
1996 Subaru SVX LSi (Red)
2019 Subaru WRX LTD
Old 06-01-2005, 11:47 AM
RFL
window switch
Try rocking the switch. Push down (hard) with your thumb on the pivot point of the little switch, and pull up on the front of the switch with your forefinger. Works on mine, every time...
Old 06-01-2005, 12:07 PM
Thanks for the suggestion, but I already tried that. I have to do that to get my passenger-side window to go up and down sometimes. This is definitly something different. I can hear something that sounds like a relay kick on when i push the switch in and kick off when i release it.
Dan Taney
2019 Subaru WRX LTD
Old 06-01-2005, 02:46 PM
thundering02's Avatar
Giong back to the beaters...
Id check the connections at the switches and motor first just in case its just corroded.
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 06-01-2005, 02:53 PM
SubaSteevo's Avatar
No longer blue member
Sounds to me like you broke your "sleeve lock regulator," a $12 piece of plastic that's about an inch long.
-Steve
01' MSM Lexus IS300
Old 06-01-2005, 03:21 PM
THat's my thought as well. You'll be able to remove the door panel and see the cable right away.
If it's broken the window will be loose and you'll be able to lift it by hand.
