Old 05-27-2005, 07:30 PM
RobertB
Shakes
The front end shakes when turning to the left at high speed. this can be set off by rough road surface but also happens if the turn in is quick on smooth surfaces. Tires are balanced, C.V.'s replaced,inboard universals replaced,
bottom ball joints replaced. If the conclusion is the struts where can I find good replacements?
Bob F
Old 05-27-2005, 07:34 PM
The struts are probably bad, but you should also check the control arm bushings. I just replaced my control arms and it made a big difference.
