Connecting dashboard tweeters
After three month of owning my '94 SVX with only 33000 miles, I found out that my dashboard houses only dummies instead of tweeters. Therefore the sound is rather flat.
Today I could finally remove my stereo cage to check, how I would have to connect aftermarket tweeters, but I could not find anything that would have brought me forward, no empty plug or cables. Does anyone know more? |
Welcome to the site. Your best bet for help on speaker replacement is to check out http://svx-iw.com/ and look for the speaker replacement instructions in the troubleshooting section.
Connecting the tweeters isn't hard, but you will need some sort of crossover arrangement. The OEM unit uses a small capacitor located at the tweeter itself. This is because the wires out to the speakers are full bandwidth - the door speakers carrying the whole signal, the tweeters using the cap as a high-pass filter.
Anyway, look for the speaker wires in the kick panels and there should be a place where they branch off to go to the tweeter location. Of course mine had OEM tweeters so, I can't vouch for wiring if your setup never had them. Do you have the wiring diagram so you know what color wires to look for? |
They're in there! You are gonna need to cut the connectors when you find them and splice the new ones in. The difference in sound is DEFINITLY worth it!
Dave W. ______________________________ 1996 Redd |
From the FSM, Section 6-3, pg.25
Driver's side [L] tweeter: Green wire and Brown wire with yellow stripe Passenger side [R] tweeter: White with black stripe and red with yellow stripe Factory tweeters have matching wires. Part number is 86301PA030 Speaker Ay $42.49 each from Subaruparts.com. Diagram is HERE .
Thanks for help, esp. the parts number. Subaru Germany is sold out. A friend in the US will order them and ship to Europe.
SVX version names are different in Europe. Mine is a German '94 model which never had tweeters in the dashboad, just dummies. But it has the stock Panasonic stereo with a CD-player in the boot holding 12 CDs. |
Yep. This is confusing because all SVX dashboards have the tweeter "grilles" built in........regardless of whether or not your car actually has tweeters. Dave |
Is it possible that your SVX does have the tweeter wires/plugs, but they have fallen out of sight? In my SVX stereo install guide look in section 2.5.1, above item "j" for the Subaru wiring diagram. The "front" speakers are the tweeters. Quote:
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
Thank's for your help. I got the tweeters from a friend in the US and installed them yesterday. It makes a difference !
According to Subaru, the German version never had them and it doesn't have the wiring pre-installed. So the biggest challenge was to find the right wires behind the kickpanels without taking the doors apart or taking the radio cage out. After pulling the plugs and connecting wire by wire until the door speakers worked, I found the rights ones. Didn't take too long as you indicated the right colors. Connecting new wires, getting the wire up to the tweeter location and fit plugs on the wire's end is the easy part. The tweeters itself plug into the original covers, after removing the inner part behind the mesh. |
I installed some tweeters out of a Ford Premium Bose system. They are larger than the subaru, but fit perfectly and have an even lower crossover than the Subaru speakers and much lower than the aftermarket speakers. Its simply amazing to actually hear vocals out of the dash instead of from your feet Doug
Thread Tools | |
Display Modes | |
