Old 05-04-2005, 09:32 AM
That's a weird one.
It could not hurt to run an extra ground to the engine or factory header, in case something tweeks the clamp/strap under load.
Old 05-04-2005, 12:39 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Ben,
If you've got the time, could you try alternate ground straps - as Tom suggests - and see if they work when the muffler strap is removed?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-04-2005, 01:34 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Yeah, we will be adding about 10 grounds although probably just another one in case the exhaust has clearance issues again until we move the battery to the trunk.
Old 07-02-2006, 02:40 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
I know this is an old thread, but Im getting the same thing.
So Im going to check my alterntor tomorrow
check fuel pressure
possibly replace the Fuel relay (its under the pass seat, right ?)
and check the ground strap, but Im probably going to
add some too.
The ground to the exhaust I take it went to the chassis somewhere ?
Ill probably just end up adding a few all around
motor to chassis, chassis to battery.
thanks for the tips
Dayle
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 07-02-2006, 10:54 PM
Speedklix's Avatar
Locker Link Solution
stockers should have one on the right tailpipe hanger.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 07-02-2006, 10:59 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Mines been broke since I got it. No probs to report from it though.
Old 08-11-2018, 01:17 PM
svxnavyvet svxnavyvet is offline
Re: No start (actually starts then dies)
This is why I like this forum over fee book. I just got a white svx had a spare engine in the trunk in the front was a japanese import motor had custom exhaust. and the back seat was missing but it was staked with parts. so removed rear engine cleaned out parts took out front seats and carpet cleaned carpet looks good in side now replaced right front with one I had same color looking better exempt for the hole in the hood and funky hood scoop. Ok now the guy said trans bad yet to see but also could not get it to keep running. I got it for 700. tried to start it it wood start and die read this post looked at the batt and head passed the factory batt cables and just had one to the starter and a ground to the stater bolt. so put the factory ground on and it not only starts but runs great exempt noisy injectors all 6 tap tap tap got some injector cleaner in now. so next is to put a seat back in and see what the trans does it also could have been funky with no grounds.
Thanks all this place is great info source.
