Old 01-27-2002, 09:27 AM
Dgf
ECU crush mod?
Can anyone tell me what the ECU crush mod does?(scoobymods.com). They give instructions on how to do it, but never say what it is for.
Thanks.
Old 01-27-2002, 11:48 AM
eclique eclique is offline
Send a message via AIM to eclique Send a message via Yahoo to eclique
DGF
I have no personal info but here is a post from the arcive when I did a 93 svx search
http://www.subaru-svx.net/archive/ar...?message=52009
try this link or do a search like I did
good luck
Old 01-27-2002, 12:45 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
I believe it's just for 92/3. I could be wrong. Just a warning though. If you don't do it right, it's 800 bucks worth of electronics that you are shoving down the drain. If your car is running fine, don't touch it.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 01-27-2002, 12:57 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
In the early SVXes, there was a complaint of "hesitation" from many buyers. It was not actually "hesitation" but, a "lag" that was built in from the factory to keep from adding too much torque to the drive train at take-off. With so many complaints, Subaru decided to provide a "fix" for this problem, which was to crush the "noise supressor" in the ECU. If you go to the "Links" button at the top of the page, then, click on the TSB's link, you'll find the link that describes the problem.
Randy Johnson
Mike Davis -- at Reading VI
Old 01-27-2002, 10:01 PM
nvrmore100's Avatar
nvrmore100 nvrmore100 is offline
Send a message via AIM to nvrmore100 Send a message via Yahoo to nvrmore100
DONT BOTHER!!!!!
I have a 92, and did it to 2 different ECU's. Both with absolutely no better performance. Unless you are really elec savy, its not worth wrecking your ECU trying.
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter
http://www.ryanmacdonald.com
http://www.digitalvertigo.net
http://www.open-innovations.com
Old 01-28-2002, 10:10 AM
northernkanuck northernkanuck is offline
I highly recommend doing this if you are experiencing the lag mentioned.
I had a serious lag with my 92 SVX and had this done, what a difference. It seems everyone has varying degrees of success and in my case it was a HUGE difference. I felt like I had a totally different car afterwards, of course make sure you disconnect the battery and follow all of the instructions very carefully. Make sure you leave the battery disconnected overnight to reset the system.
Good Luck, Keith
