Camshaft sprocket wrench
The manual says to use tool # 499207100 to keep the camshaft from turning when I try and loosen the bolt. I can't find a picture anywhere and Subaruparts.com has the item discontinued. Does anybody have a picture of one? Is it really needed? I was going to rig something up but if you guys think I might damage something I'll try and buy one. Hey, I'm always up for buying more tools Either way I need to figure out a way to remove the camshaft sprocket. Thanks
Kent |
if you have an impact gun you would not have to use the tool... why are you removing the sprocket?
I made this for mine
I was planning on replacing the cam seals and put in a new water pump while I'm down there. Thanks for the pic immortal. Maybe I'll try and put something together today.
Kent |
