Old 12-26-2004, 11:48 PM
NapaBavarian's Avatar
Good morning!
4.11 from an early Legacy?
I can pick up an early AWD legacy traney from pick-n-pull and the gears all match the SVX, I compared '90 legacy to '92 SVX, and I would rebuild it with the level 10 kit, what would I need to upgrade to make it match the SVX?
Edit- I plan to add a stage 2 Ecutune and a camshaft, and full exhaust replacement.
.Karl.
Old 12-27-2004, 05:37 AM
It should be a plug and play swap form an early 90's Legacy, besides the swapping of the rear diff ring and pinion to retain the LSD and use the SVX rear Axles....you'll need to either get your SVX torque converter rebuilt, OR if you want to use a Legacy TC, you'll need the Legacy Flexplate...
