Old 10-06-2004, 10:23 AM
tracedog67
tilt steering
Fellers,
The tilt steering on my '92 SVX LSL will only go in the bottom position or the full top position(which doesn't lock in), am I doing something wrong with this thing? In the bottom position I can't see the gauges the way i fully should.
thanks
tdog
Old 10-06-2004, 10:35 AM
svx_commuter's Avatar
Oh that's a common problem. I think you are using the the lever on the left side of the column that says "LIFT". That's just to get the wheel out of your way when you get in or out. The "tilt" release/adjust is on the bottom in the middle of the column.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-07-2004, 06:19 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
This should make it into the new FAQ!
Old 10-08-2004, 02:51 AM
Without an owner's manual, the adjustment levers are well hidden all right.
Yep!, put it in the FAQ. Frequent problem it is.
Old 10-08-2004, 06:47 AM
I had the same problem when I got the X. I was thinking then and thought at the time..."It's broken " Why can't I adjust the tilt to where I want it. Hum Poll? anyone?
