Old 11-08-2001, 12:36 PM
Brian Steel
Higher stall speed torque convertor
Has anyone looked into or tried a higher stall speed torque convertor? Just thinking that with the tall gearing, it might help the off line performance and would not negatively affect the high speed performance.
Brian
http://www.smallcar.com
Old 11-08-2001, 01:41 PM
cocacola08's Avatar
cocacola08 cocacola08 is offline
Send a message via ICQ to cocacola08 Send a message via AIM to cocacola08 Send a message via Yahoo to cocacola08
I've thought the same thing, but have no idea who would have one.
You guys w/level10 do they have a higher-stall speed TC?
Kev
kevin.m.sheets@verizon.net
Old 11-08-2001, 03:57 PM
Lowered SVX
i think they do.....
in my sport compact car magazine i saw a universal high stall torque converter. if i remember tonight i will post the info.
"Too much fun to drive!"
Old 11-08-2001, 05:44 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Re: Higher stall speed torque convertor
You can get your existing TC modified by Level 10 for $600.
I think the TC mod helps a little, but it is not like adding nitrous or anythng
If I was not having my tranny rebuilt at the same time, I doubt if I'd bother, but that's just my opinion
Brian
'20 Honda Ridgeline
http://www.x35design.com
Old 11-08-2001, 05:59 PM
It'd make it launch better, but in turn it would help launch the tranny to the rebuilders much sooner, the best thing would be get a lower geared tranny and rear diff, say...out of a Turbo Legacy, they have the same amount of clutch packs as the SVX (more than a standard Legacy tranny) they also have a LSD rear diff and 3.90 gears which are lower than the 3.54's in the SVX (of course the standard Legacy's had 4.11's very low gears).
If you look around you'll likely to find one for less than $1000, and I garrantee it'll make a bigger difference than any other mod in your timeslips (except maybe nitrous) and lower gears are easier on your tranny.
Just something for you to think about
Old 11-12-2001, 11:52 AM
SVXtypeR
Brian
Yes, I have the Level 10 Stage 3 with a high-stall tc. Although it's nice to have the power lock-up higher in the band, I i've lost some of the H-6's "grunt" down low so it's an even trade off (my et's are pretty much the same).
Old 11-20-2001, 12:05 AM
kvnobrien
I've experienced the same as SVXTypeR. I lost some low end power with the high stall speed TC.
Old 08-20-2007, 08:08 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Has anyone else had this modification done to their car? Instead of just the 'feel' of low end power loss, does anyone have any 0-60, 1/4 mile or dyno data of the difference? Specifically, I'm looking for differences in 1/4 mile time. Thanks for any info.
Kevin Thomas
***R.I.P***
Old 08-20-2007, 11:44 PM
It's Just Eric's Avatar
Missing in action
my old fwd L had a higher stall tc in it...It seemed to make the engine wind up a tiny tiny bit faster, but that's about all. I could launch it at a higher RPM, but being fwd...it didnt get to the ground
now...Dont quote me on this, but I seem to recall somebody saying that you cant or shouldnt use a high stall tc with the 4.44 tranny. I wanna say svxfiles would probly know if tha's true or not
R.I.P Cool Signature.
Old 08-21-2007, 03:53 AM
Thank you, once again Eric the Red.
The stall speed is a variable dependent on design, engine power, and perhaps, gearing.
For example, take a C-6 torque converter behind an inline 6, and it has a stall speed of say 2400 rpm.
Take the same TQ behind a 351M and it now has a stall speed of 3000rpm.
If you could bolt it to a 460, it now has a stall speed of 3500rpm, and your very hot transmission launches great untill it melts!
A 4.44 Outback torque converter should have a slightly higher stall speed than say a SVX TQ, but it is not really noticable.
(Been there, done that.)
An Impreza/Legacy TQ could cause your trans to run hotter and fail, not reccomended.
For stock gears you can ONLY use a SVX TQ.
Unless you like replacing things.
With a 4.44 you can use either a SVX TQ or a 4.44 TQ with no ill results.
I hope this helps.
Old 08-22-2007, 05:30 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
I hope this helps.
Yes, it does help. My question now is...what if you use a 4.44 TQ with a 4.44 geared SVX, will this combination have a higher flash stall speed than a 4.44 geared SVX with a stock SVX TQ? Would it be worthwhile to get a modified TQ, a TQ from a 4.44 geared car (Like the Outback) or just leave the stock SVX TQ on (with the already 4.44 geared SVX)?
I understand the extra heat that could be generated. All of my cars have a tranny cooler, except the SVX.
Kevin Thomas
***R.I.P***
Old 08-22-2007, 06:28 PM
As I remember the differance in stall speed was only 200-300 rpm.
And that differance could be explained by different power levels and engine state of tune.
I know my Claret has a SVX TQ, my Pearlie had a OB TQ, Nicks has an OB, and I don't remember the "other Pearlie".
However my Claret is the only one that I drag raced.
Old 08-22-2007, 09:57 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Good information! I appreciate your feedback.
Kevin Thomas
***R.I.P***
