Old 07-01-2004, 11:07 AM
TCU code check, existing problems
To perform the TCU self diag test for EXISTING problems
1) Warm up engine by driving at speeds greater than 12mph.
2) Stop vehicle and turn ignition switch OFF.
3) Turn ignition switch ON and make sure POWER indicator lamp comes on.
4) Turn ignition switch OFF.
5) Move selector lever to D and turn manual switch ON.
6) Turn ignition switch ON.
7) Move selector lever to "3" and turn manual switch OFF.
8) Move selector level to "2" and turn manual switch ON.
9) Move selector lever to "1" and turn manual switch OFF.
10) Partially depress accelerator pedal (to turn idle switch off).
11) Check code as displayed on POWER light. Blinking once every 1/4sec is normal.
more info than you asked for...
Old 07-01-2004, 11:09 AM
TCU code check, for previous [stored] problems
To perform the TCU self diag test for PREVIOUS problems
5) Move selector lever to "1" and turn manual switch ON.
7) Move selector lever to "2" and turn manual switch OFF.
8) Move selector lever to "3" and turn manual switch ON.
9) Move selector lever to "D" and trun manual switch OFF.
more powerful information
Old 07-01-2004, 11:11 AM
What the TCU trouble codes mean
Trouble codes:
11. Duty solenoid A
12. Duty solenoid B
13. Shift solenoid 3
14. Shift solenoid 2
15. Shift solenoid 1
21. ATF temp sensor
22. Atmospheric sensor
23. Engine revolution signal
24. Duty solenoid C
25. Engine torque control signal
31. Throttle sensor
32. Vehicle speed sensor 1
33. Vehicle speed sensor 2
that's all she wrote
Old 07-06-2004, 05:59 AM
The Monzta's Avatar
The Monzta The Monzta is offline
Re: No Word yet?
Originally posted by svxistentialist
No Monzta
Those files are not empty. It's just that all of them except the last one are Word documents. You using a Mac or something? Have you got Microsoft emulation software?
If you click on the link again, then click on Engine, then click on Codes, the last file, list of Engine Codes is a bitmap, .bmp, it's laboriously big on my slow system, but you should be able to read all the codes from it. [remember to enlarge it!]
I will cut and paste the text from the ones you want in the next couple of posts, OK?
Joe,
Thanks for all those posts. I couldn't see the link in your first post because our computer system here at work has so many firewalls and anti-virus programmes that sometimes I just can't open even simple links. Once I got my machine at home back together after a rebuild I was able to click on the link and everything was fine.
Armed with all the info you've given me I shall have a crack at checking the codes tonight. Will keep you posted.
Thanks again.
The Monzta
'96 Subaru SVX (111K) - UK spec
'85 Opel Monza GSE (71K)
'86 Opel Monza GSE (95K)
'93 Toyota Estima Lucida (37K) - JDM import
My psychiatrist says I'm suffering from paranoia........but he's always hated me!!!
Old 07-06-2004, 11:50 AM
Cool Cool
You're welcome. I hope the codes show up something simple and curable.
BTW, have you checked on the JAE Billings thread? The show is on 24/25 July if you fancy coming, and meeting more members.
Saturday night is likely for the knees-up.
See you there if you're coming.
But let Phil Hill know straight off if you're putting your car on the stand any day Wednesday the deadline!.....
Old 08-22-2004, 01:10 PM
The Monzta's Avatar
Finally got the codes checked by my mechanic. The fault seems to be a knock sensor problem. Can anyone confirm how many there are on the engine? I believe it's two, I know where one is (just behind the alternator) but if there is another, where is it? How easy, or should I say difficult, are they to fit?
Finally, where would be a better place to get them from that would be cheaper than Subaru? Are the ones fitted to the American engines the same as ours?
Glenn
The Monzta
Old 08-22-2004, 05:04 PM
R? L ?
Glenn
If your mechanic can check the codes, he[she?] ought to be able to specify which knock sensor it is that is causing the problem.
Code 22 is for the RH knock sensor, and code 28 is for the LH sensor, so it should be obvious.
I am not sure exactly where they are fitted, but there is one for each block of cylinders.
They must be really easy to fit. The US ones are sure to be the exact same, and 1stSubaruParts will post them to you.
