Old 06-04-2004, 03:55 PM
Xodi-SVX Xodi-SVX is offline
Security "clicker"
My security clicker and my keys to the SVX were ganked by someone at a party last night and no one can find them at all. We've looked everywhere and they're just missing. I'm not too concerned about it, I just want another clicker since we can't find this one.
My friend has a clicker from a 95 SVX. I was wondering if the clicker is compatable with the system on a 92 SVX.
Thanks.
'92 Black on Black Subaru SVX LS-L with the touring package. 198,551 upon time of death.
130k miles when I bought her May 28th
June 10th, 2004 -- Never forget. Well, at least I won't =( *Mourns for his rear-quarter panel*
September 20, 2005 -- The day she finally gave up the fight
April 25th, 2006 -- Bought another SVX!
'92 Teal on Black Subaru SVX LS-L with the touring package. 133k miles when bought on April 25th.
... 135908 as of May 7th =)
Old 06-04-2004, 04:24 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
I am pretty sure that all the remotes were the same. You will just have to reprogram the new remote.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
It should be
I am currently using a key fob from a 95 on my 93 and it works fine. It doesn't have the same reach that my original does but it works just fine. You will just have to go in and reprogram your car to accept the new key fob signal. I would suggest that you clear out the old one if its not found. It can store up to 3 in its memory. If you do a search here on the club you should be able to find the instructions on how to reprogram it. It only takes about 5 minutes to do.
~ray
PS.. in order to clear out the code of your old key fob you will have to put the code for the new one in all 3 memory slots, otherwise it will just add this new one to the list. Put it in 3 times and it should overwrite the old code.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 06-04-2004, 04:29 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
do all svxs have the remote access because i have a 92 lsi and the factory security system but no remote i bought it used
Old 06-04-2004, 08:16 PM
All you would need to do is get a "clicker" and program it and it should work. Not all of the cars had the security system in them.
If you can't find the directions for the programing, let me know and I can give you a link to them.
