Old 03-26-2004, 02:56 AM
Nobody Nobody is offline
Send a message via ICQ to Nobody Send a message via MSN to Nobody
Front doors creaking
Hiya,
I recall my small problem with front doors. They creaks! I tried almost everything but nothing helped. Hinges are ok, the sound goes from thing I call door stabilizator (it is piece of metal in the center of door between upper and lover hinge and is responsible to keep open door in different positions). Hope I decribed it well. Definitely this problem I had with all old cars I ever had. The most drastic solution is put it away but than doors do not stay in any position when opened.
Any advice?
Peter
Old 03-26-2004, 06:15 AM
michael's Avatar
michael michael is offline
What Potholes ???
If its all rusty and goey from grease etc. clean it off really good and spray it with some white lithium grease it's waterproof it gets into the door where other grease can't reach and it doesn't drip black crap onto your paint! You can find it at most auto parts stores.
Wanted: Steering Wheel
Old 03-27-2004, 05:21 AM
Thumbs up
Thanks Michael.
Spot on advice. I did exactly that job last weekend, except I used black graphite grease instead of lithium.
Motorcycle chain spray grease is good too, it clings well because it has "anti-fling" properties to allow it stay on a high speed chain. Just be careful where you spray it, it's hard to get off.
Old 03-28-2004, 01:49 AM
Thanx, Michael, Joe,
the rust is definitely somewhere inside door, I will try to find some good grease or use moto chain spray. I will let you know if I succeed.
Peter
Old 03-28-2004, 01:51 AM
Green1995SVX
I had this problem. I took the car to the Subaru Dealer last week and they solved it for me and there was no charge. I will inquire as to what they did to fix it.
Mike
Old 03-28-2004, 01:53 AM
OK thanx a lot, Mike.
Peter
