Old 03-09-2004, 04:30 PM
mark10t
Originally posted by Tim-H
subaru made a 4 cyl engine with the same piston sizes as the eg33 but lower compression. The easiest thing would be a piston swap from that engine. I can't remember the model number anymore though. This route would be a heck of a lot cheaper than custom forged pistons.
You're probably thinking of the turbo 2.2L engine as used in '91 to '94 Legacy's (like the '91 Legacy Sport Sedan I had prior to the SVX). Good engine that (I was told) could tolerate a lot more boost.
-Mark
Old 03-09-2004, 04:31 PM
Sonar's Avatar
Sonar Sonar is offline
The way I see it, the EG33 is a 2.2L times 1½
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 03-09-2004, 07:21 PM
Green1995SVX
Originally posted by Landshark
the same thing my 928 had, in 1987.
ohhhhh ahhhhh... I'm AMAZED.
Old 03-09-2004, 07:51 PM
Subafreak's Avatar
Superbeast
That kinda pisses me off that Subaru has now made a N/A 3.0L that makes 20more HP that our beloved EG33. I guess it was bound to happen some time.
What I really want to know is what they did to that motor to go from 212hp to 250hp, couse that ain't to shabby for a 3.0L.
Old 03-09-2004, 08:24 PM
go have a Starbuck's.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 03-10-2004, 09:52 AM
svxsubaru1's Avatar
Subaru is also going to make a 3.6 liter for there 7 seater thats spose to have over 300 horse. Also our eg33 has more torq than the new 3 liter 217, 227.
Also if i was building the eg33 to be turboed i wouldent use the ej22t pistons becasue there cast. I know je has some good pistons forthe ej22t.
Old 03-10-2004, 03:06 PM
Do you have a diagram or pic of that system. I would like to check it out.
Old 03-10-2004, 06:30 PM
svxpert svxpert is offline
EZ30
the 6 in the legacys now is the EZ30 212HP@6000 210TQ@4400 10.7 : 1 ratio. it has two timing chains instead of timing belts.
Old 03-11-2004, 09:45 AM
svxsubaru1's Avatar
Subaru changed the crank to eg33 style and put varible valve timing and lift on it to get the extra umph out of the engine.
Old 03-12-2004, 08:36 AM
Porter
There is a new B4 variant in Europe with the 250hp NA EZ30, the STi 6-speed manual transmission, the full Bilstein treatment, and will be available in wagon versions.
http://www.subaru-global.com/topics/...gen/index.html
Here's a quick shortcut to the info:
http://www.subaru-global.com/lineup/...pecB/main.html
Old 03-14-2004, 07:09 AM
couldn't find a good diagram, but there's a few pics on here...
http://members.rennlist.com/v1uhoh/Flappy.htm
it was a vacuum-actuated valve (affectionately known as the 'flappy') that changed the intake path at around 3500-4000 rpm, if i remember right. i'll try to find a better explanation or diagram when i get home.
do you have a good explanation/diagram of how the one in the SVX works?
Old 03-14-2004, 02:24 PM
Breck SVX
Originally posted by NomadTW
best buildup for the eg33
Whats that out of?...an airplane? It looks like theres a shock in there.
Old 03-14-2004, 02:27 PM
i believe that's from a dune buggy.
Old 03-14-2004, 06:01 PM
GreenMarine's Avatar
From POST-***** to LURKER
That is definitly not the best build up for the SVX... You would never fit that under the hood... Try a centrifical supercharger instead of a roots type... That would work tons better...
Old 03-15-2004, 06:51 AM
Michael Blue's Avatar
Michael Blue Michael Blue is offline
Sold. :'-(
Originally posted by GreenMarineSVX
...Try a centrifical supercharger instead of a roots type... That would work tons better...
Well, it might fit better, but centrifugals have many drawbacks as well. If I were going to pressurize the SVX, I'd be using a Lysholm.
'92 Pearl White LS-L Touring SOLD
4.44 Swap, trans cooler, trans filter, trans temp gauge
Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines
Raxles front axles
