Old 02-14-2004, 04:02 PM
Chicane Chicane is offline
Anti-BS Vigilante
What RPM should my car be shifting at?
It seems to shift at 6100-6200rpms somewhere... shouldn't it shift at 6500???
- Rob
Old 02-14-2004, 05:29 PM
immortal_suby's Avatar
Thread Killah
Yes, it should shift at 6500 in power mode or if you are manually shifting.
Locker Link
2015 BRZ Limited 6MT
Old 02-14-2004, 09:40 PM
GreenMarine's Avatar
From POST-***** to LURKER
That's what mine could shift at... But I never take it over 5,500 rpm... There's no real need to with the 5 MT... Plenty of torque...
Old 02-15-2004, 10:47 AM
Anti-BS Vigilante
Yes, but mine DOESNT shift at 6500rpms.. it shifts at like 6100-6200 somewhere.
What gives?
- Rob
Old 02-15-2004, 10:49 AM
Thread Killah
One guess - mine shifted at a much lower rpm when the air filter was soaked with water.
Maybe check your intake?
Other than that I don't know.
Locker Link
Old 02-16-2004, 06:15 PM
Anti-BS Vigilante
I have a stock air filter and it's fine.
Anyone have any ideas?
- Rob
Old 02-16-2004, 09:36 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
with the 5speed in hits freaking fuel cut at 6500 rpm(will float a tiny bit higher) so im assuming that redline is a littler lower then that. What a shame, our engines are good so far past that but there dosnt seem to be away to implament a FCD, just go standalone.
phil
~Phil
Old 02-17-2004, 05:56 AM
RSVX RSVX is offline
Network Design Administrator
- Rob
Cause thats when your TCU is telling it to shift
Life is a game. Play to win.
Old 02-17-2004, 07:57 AM
mbtoloczko's Avatar
sans SVX
Re: What RPM should my car be shifting at?
- Rob
In power mode, mine usually shifts at 6500. On one occasion, I watched it shift at nearly 7000 rpm. Maybe you could try installing a TCU from a later model SVX.
Mychailo
Visit my locker
Old 02-17-2004, 04:58 PM
Mr. Pockets's Avatar
Moderator
I'm pretty sure that, under power mode, my car will shift before 6,500 - possibly the 6,100 or 6,200 Rob describes. The shifts are, after all, sort of long and soft - so waiting until 6,500 would mean that the engine would hit the fuel cut.
I'm not sure what engine speed the car would shift at, in manual mode, to save the engine. I would assume the same speeds.
My car reliably shifts into 2nd at approximately 40mph and 3rd at approximately 80mph. I haven't been in power mode for the 3-4 shift recently.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 02-17-2004, 05:58 PM
mbtoloczko's Avatar
sans SVX
Mine definitely starts selectively cutting out cylinders before it shifts. The cutting starts after 6000 rpm, but before 6500 rpm.
Mychailo
Visit my locker
