Old 02-09-2004, 07:44 PM
carfreak85
Suspension interchangeability
Does anyone know if suspension parts from GC8 or GDB Imprezas can be swapped over to an SVX?
Old 02-09-2004, 08:45 PM
mbtoloczko's Avatar
sans SVX
The struts are definitely not interchangeable, and the strut mounts are different too. Swaybars and hubs are different too.
Mychailo
Visit my locker
Old 02-09-2004, 10:57 PM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
i thoguht that the struts were the same but not worth it because of the extra wieght of the svx
SV What?
Old 02-09-2004, 11:38 PM
mbtoloczko's Avatar
sans SVX
The strut-to-hub bracket on the SVX strut is different than that on other Subarus. I don't know about any similarities of the SVX strut internals to any other Subarus.
Mychailo
Visit my locker
Old 02-10-2004, 05:01 AM
wawazat??'s Avatar
Yeah, I'm still around
Front suspension arms are different as are their mounting points. Front and rear swaybars are different. Rotors and calipers are different.
Todd
Down to none
Old 02-10-2004, 06:27 AM
Green1995SVX
Everything is completely different. Even the internals of the struts are different. If i recall correctly, the SVX uses Showa struts while other subarus use KYB.
Mike
Old 02-10-2004, 08:47 AM
wawazat??'s Avatar
Mike
You are correct sir!
Todd
Down to none
