Old 08-09-2003, 10:22 PM
Imprezzed's Avatar
Imprezzed Imprezzed is offline
Some Toolbox rolled it!
Send a message via Yahoo to Imprezzed
Bong Bong Emergency Stations Emergency Stations
Okay, here's the situation. Coming back from the movies (Bad Boys II...awesome!) Pull in for gas, put 48 Liters ( A LITER OF COLA....Super Troopers) And I go to start my baby...and the engine turns over and dies. I'm thinking awww crap. It's 1:48 in the morning, the gas station is empty. So this guy somes around and gives me a boost. It starts just fine.
SO - it's either
a) alternator
b) battery
I'm leaning towards A because the alternator was making funny noises. The only things I have that aren't stock on the car is a Strobe light system (which was off), A Pioneer deck, and a 250 Watt amp. The amp is now disconnected until I get this resolved. So far, after paying 10-5 for my SVX, I've had to:
a) $1000 worth of front brake, suspension and CV axle work
b) $100 for a new driver's side upper window
c) $75 for a K&N Filter (the old one was shot)
Grr...why is my dream car so expensive! *Sigh*
EDIT: Does the SVX have a history of bad alternators? What else could be the problem?
1992 SVX LS-L Claret - RIP.
Old 08-10-2003, 06:12 AM
svx_commuter's Avatar
How long have you had the SVX and how much has it cost you?
An Impreza 2.2L is a lot less $ to maintain.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 08-10-2003, 07:24 AM
mikecg's Avatar
mikecg mikecg is offline
check the belts first. I thought I had a bad Atlinator once. Took the car it they tested it it was fine. They tightened the belts and I had no more trouble. Another why to eliminate the battery would be to start the car and then disconnect to battery. If the car runs with the battery disconnected the Altinator is butting out voltage, if the engine stalls, then it ain't. (Back yard machanic trick)
Old 08-10-2003, 07:58 AM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Don't do this unless you want to blown your ECU
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 08-10-2003, 08:20 AM
mikecg's Avatar
Really
Didn't know that. Sorry. I guess there is a chance of a surge. Though I would hope the fuses would go first. Thanks for correcting me.
Old 08-10-2003, 08:35 AM
red95svx
NO NO NO!!
Yikes!
Don't EVER disconnect your battery while your car is running! That trick might have worked fine for your uncles 72 Plymouth, but it could fry the electronics on a newer car. Why take the chance? Buy a cheap voltmeter and do it the right way.
Old 08-10-2003, 09:51 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Clean the battery leads. Even if they look clean. I have had that problem many times, and it doesn't cost anything.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 08-10-2003, 11:03 AM
svxeno
Could also be a cell shorting in the battery. That can really make the car act screwy. <--technical term.
Randy ii
